Page: |
Home > For Sale > Teflon Bar For Making Gudgeon Pin 'Buttons' | |||||||
11046 Posts Member #: 965 Post Whore Preston On The Brook |
4th May, 2014 at 05:20:34pm
340mm of Teflon round bar for making gudgeon pin buttons. Used to prevent floating pins from gouging the bores. Not every application require this, as floating pin pistons these days have pretty good circlip retention. If like me however you use floating pin little end con rods with press fit pin pistons, there are no circlips, and the Teflon is tequired to stop the pins damaging the bore.
2742 Posts Member #: 637 Post Whore Hertfordshire |
22nd May, 2020 at 09:05:34pm
Do you still sell these? Or anyone know where I can get some from? My build thread..
2629 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
22nd May, 2020 at 09:11:42pm
the round bar itself can be purchased very easily. Ive purchased some previously from IIRC a vendor on Ebay called performance plastics. RS are likely stock it too.
22nd May, 2020 at 09:30:13pm
I haven't got a lathe so not sure how I'd make them. What size is the hole Inn the end of the gudgeon pin? I forgot to make a note of it when I left the barn earlier My build thread..
22nd May, 2020 at 09:32:31pm
If you supply the material and a drawing with dimensions I can make them for you if needed.
22nd May, 2020 at 09:52:21pm
How does Teflon machine? Some plastics I don’t mind but others are awful. On 17th Nov, 2014 Tom Fenton said:
22nd May, 2020 at 10:05:54pm
Cheers Shane I might be in touch 👍 My build thread..
22nd May, 2020 at 10:06:38pm
I've found it ok once you find the sweet spot with speed and feed.
Page: |
