Page: |
Home > Technical Chat > Cheap running in oil. | |||||||
1425 Posts Member #: 9199 Post Whore Lancashire |
28th Apr, 2014 at 02:11:36pm
Looking for some cheap oil to knock the cam in and run the mini for a week before changing and running Millers CTV.
10021 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
28th Apr, 2014 at 02:20:03pm
I just go to local motor factors and buy the cheapest 20/50 I can. If something is worth doing, it's worth doing half of. |
1043 Posts Member #: 10424 Post Whore Swansea boyo! |
28th Apr, 2014 at 03:29:09pm
We saw 20/50 in Morrisons earlier for £10 earlier! Or grab someone with a halfrauds trade card and get theirs for £14 or something like that. Edited by Shauna on 28th Apr, 2014. They don't die, they just get faster! |
28th Apr, 2014 at 03:43:33pm
Should i be looking at mineral or semi ? Edited by lee.pb on 28th Apr, 2014. What the mind can conceive the mini can achieve
28th Apr, 2014 at 03:55:02pm
Mineral If something is worth doing, it's worth doing half of. |
28th Apr, 2014 at 03:55:13pm
Cos its cheaper and apparently helps bed things in. Edited by John on 28th Apr, 2014. If something is worth doing, it's worth doing half of. |
6729 Posts Member #: 618 Post Whore Glasgow |
28th Apr, 2014 at 05:37:30pm
I actually got mine from b&q last weekend. Didn't get the cheapest stuff which was £11 as it wasn't suitable for turbos. Not sure if it was an issue for running in or not but i got the slightly better stuff rated for turbos ad i'll be running it in for a few miles on it |
28th Apr, 2014 at 08:21:00pm
I may check B&Q as theres one near work.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
28th Apr, 2014 at 09:43:41pm
my own opinion is that why put cheep shit in an expensive engine especially at the crittical running in stage when there is a specific running in oil available, all be it maybe not at your local store?...........
4890 Posts Member #: 1775 Post Whore Chester |
28th Apr, 2014 at 09:53:44pm
I used cheap 20 50 to knock the cam in dropped the oil and swapped to millers running in oil, then had the engine run in on the rollers under different loads by my local operator.
29th Apr, 2014 at 06:43:02am
The idea is to knock the cam in on cheap ish oil and maybe a couple of runs up and down the lane at various loads.
29th Apr, 2014 at 09:04:15am
im with sprocket, why risk it? |
29th Apr, 2014 at 09:05:29am
29th Apr, 2014 at 09:40:30am
Mine will be knock cam in and whatever garage running occurs. Then change for MOT and a quick run up and down the road then on to CTV. If something is worth doing, it's worth doing half of. |
Page: |
