Page: |
Home > Technical Chat > FPR take offs | |||||||
1425 Posts Member #: 9199 Post Whore Lancashire |
22nd Apr, 2014 at 11:54:53am
Can the FPR takes offs be replaced with a smaller bore connection.
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
22nd Apr, 2014 at 12:29:50pm
Could you use something like this? Use a little bit of 4mm hose, one of these and then the 8mm. http://www.advancedfluidsolutions.co.uk/8m...ctor-2245-p.asp On 26th Jan, 2012 Tom Fenton said:
22nd Apr, 2014 at 02:51:45pm
Been looking at them but also need a feed to boost controller so a T would be required.
22nd Apr, 2014 at 03:41:58pm
You could use this http://www.advancedfluidsolutions.co.uk/8m...-bar-2302-p.asp
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
22nd Apr, 2014 at 05:08:20pm
if you can grip them hard enough you can pull the brass/copper fittings out the ally fpr ( what ever there made of)
Edited by Brett on 22nd Apr, 2014. Yes i moved to the darkside
24th Apr, 2014 at 09:53:35am
Managed to remove 2 of the fittings and demolish the other 2 so they have been drilled out.
On 22nd Apr, 2014 Brett said:
if you can grip them hard enough you can pull the brass/copper fittings out the ally fpr ( what ever there made of) cutting them off and drilling them out is another option, replace with something like this http://www.ebay.co.uk/itm/BSP-TAPER-THREAD...=item5d3365081e What the mind can conceive the mini can achieve
Page: |
