Home > Technical Chat > MJ Load scale
lee.pb
Member #: 9199
Lancashire
Simple question been looking at MJ maps and if 100 kpa is wide open on a n/a engine.
What is 16 psi in MJ kpa ?
Or what does each 10 kpa after 100 work out in psi.
10kpa = 1.4 psi
16 psi of boost would be about 215 kpa as its atmospheric pressure (100kpa) + boost.
Edited by matty on 10th Apr, 2014.
lee.pb
Member #: 9199
Lancashire
Simples lol
So will be using a base map with a max load of around 230 kpa :)
On 10th Apr, 2014 matty said:
10kpa = 1.4 psi
