Home > Technical Chat > Fuel Lines
lee.pb
Member #: 9199
Lancashire
Since the SPI / MPI lines i have dont fit a 90's mini and already bought the 8mm and 10mm copper line.
How have you gents done your flow and return lines.
Pictures would be a great help.
MarkGTT
Member #: 1194
Shropshire.
Just routed it through the car, think I used 8mm ID supply and return.
wng691s clubby
Member #: 9252
Cleethorpes
run them were the normal lines run then up the inside of the steering rack using rubber p clips and stainless pop rivets
Edited by wng691s clubby on 6th Apr, 2014.
Done now needs redoing lol
lee.pb
Member #: 9199
Lancashire
Still have the original single line so could copy that again and then make a second with the p clips installed to get the right distances.
Its just the going up the back of the subframe that my need some thinking with 2 lines.
wng691s clubby
Member #: 9252
Cleethorpes
depends where your fpr is located both my lines go over the steering rack bulkhead side and up to my regulator but thats the way i fitted my fpr
