Home > Technical Chat > GT1752 Water feed
lee.pb
Member #: 9199
Lancashire
Done the usual search and looking at removing the bolt on the rear of the block near the clutch and fitting a banjo for the water feed to the turbo if this can be done. Already have the genuine saab water pipes that are 8mm OD
Does anyone know the thread pitch for the banjo bolt?
Also would you return the water back to the top of the radiator as need to get some alloy welding done so getting an additional 8mm pipe welded on my alloy rad is no issue.
Either m14 x 1.5 or m12.
lee.pb
Member #: 9199
Lancashire
Cheers Andy, may just take the bolt to the Hydrolics shop so no mistakes are made.
Still need answer about the return to the radiator?
tadge44
Member #: 2500
Buckinghamshire
That is where mine goes.
I found that the water feed from the back of the block runs very close to the turbo hot side and I have a short length of silicone hose in it, well wrapped in heat resistant cloth.
Nick warwick
Member #: 8926
Sheffield
Lee just a thought before you get everything sorted out for the block, the downpipe does come across this water outlet hole slightly so consider a 90 straight out of it.
lee.pb
Member #: 9199
Lancashire
Seen the 90 on your build buddy, looking at coming out the block with a banjo to a small piece of silicone hose to connect uo to the standard sabb water feed since i have them.
Nick warwick
Member #: 8926
Sheffield
The 90 I have at the moment is too big so as you say a banjo into the block would be ideal
lee.pb
Member #: 9199
Lancashire
Cheers fo rthe heads up Nick.
Do you know the thread size M14 / M12 ?
Nick warwick
Member #: 8926
Sheffield
For the block thread? Its 1/4 bps
fixitphil2
Member #: 10945
scarborough/ northyorkshire
im trying to fit water pipes for my gt1752 turbo but dont seem to have the bolt on the back of my block ,what block are you using if you dont mind me asking.
