Page: |
Home > Help Needed / General Tech Chat > Carb Rebuild Help Needed | |||||||
168 Posts Member #: 10666 Advanced Member California, USA |
28th Mar, 2014 at 02:02:26am
All,
28th Mar, 2014 at 01:38:13pm
I cant remember the spindle, but the choke ones definitely do not fit and I had to buy some separate o rings to suit. |
28th Mar, 2014 at 07:42:53pm
Thanks for the help. I'll try and source some o-rings at the hardware store.
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
29th Mar, 2014 at 10:55:09pm
Looking at the pictures i would suggest the larger seals for the spindle, fitted as per the bottom seal in the picture.
29th Mar, 2014 at 11:13:32pm
Lee: Thanks so much!
30th Mar, 2014 at 08:30:22am
Apologies for the poor photoshop lol i'm no Oli with it.
1st Apr, 2014 at 01:13:38pm
Heard back from Burlen today about the spindle shaft o-rings. Looks like I've been a bit daft:
1st Apr, 2014 at 10:11:12pm
Your looking about 2mm for the plastic washer.
6th Apr, 2014 at 10:27:47pm
Thanks a ton! Got the carb mostly back together (lost the needle spring). 2mm seems a bit right on the washer and it definitely is not used to compress the seals. Thanks! |
7th Apr, 2014 at 06:35:39am
On 6th Apr, 2014 seahuston said:
Thanks a ton! Got the carb mostly back together (lost the needle spring). 2mm seems a bit right on the washer and it definitely is not used to compress the seals. Thanks! What the mind can conceive the mini can achieve
Page: |
