Page: |
Home > Wanted > Turbo housing bolt | |||||||
537 Posts Member #: 8926 Post Whore Sheffield |
20th Mar, 2014 at 09:19:33am
Hi
10021 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
20th Mar, 2014 at 09:55:39am
Nick,
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
20th Mar, 2014 at 10:08:44am
You need to clock it so the feed is at the top. The drain relies on gravity.
20th Mar, 2014 at 10:09:23am
How would i clock it mate?
20th Mar, 2014 at 10:11:19am
Turn the centre housing so that the drain points down and the feed points up. If something is worth doing, it's worth doing half of. |
20th Mar, 2014 at 10:17:44am
Guessing this is done by undoing the bolt i need? |
20th Mar, 2014 at 10:20:53am
The exhaust housing is fixed as it has to attach to the manifold. Undo the bolts on the exhaust housing to rotate the centre section to where it needs to be. Then undo the bolts you have highlighted red to rotate the compressor housing to where it needs to be. Done.
20th Mar, 2014 at 10:26:17am
Cheers Tom
3588 Posts Member #: 655 Post Whore Northern Ireland |
20th Mar, 2014 at 11:42:07am
Turbo parts will likely be metric, Mini parts will be imperial.
20th Mar, 2014 at 02:09:10pm
going to nip into a fasteners place after work |
126 Posts Member #: 10212 Advanced Member Sleaford Lincolnshire |
20th Mar, 2014 at 10:00:22pm
Nick
Page: |
