Page: |
Home > Wanted > Front disc hub passenger side | |||||||
537 Posts Member #: 8926 Post Whore Sheffield |
27th Feb, 2014 at 01:31:30pm
Found out mine has been fitted with old drum brake wheel bearings for some reason!
4890 Posts Member #: 1775 Post Whore Chester |
27th Feb, 2014 at 03:33:42pm
Can't you just change the bearings I run a supercharger and I don't care the TB is on the wrong side.
149 Posts Member #: 9991 Advanced Member lichfield ,staffordshire |
28th Feb, 2014 at 03:23:46am
pretty sure i have one , ill have a double check next time im home :) |
28th Feb, 2014 at 08:26:22am
On 27th Feb, 2014 gr4h4m said:
Can't you just change the bearings Rather not run it with the bodged drum bearings in it now i know they are in mate. |
Forum Mod 4828 Posts Member #: 154 Post Whore Midlands |
28th Feb, 2014 at 08:52:15am
I always use drum bearings in my disc hubs, have done for years. On 20th Oct, 2015 Tom Fenton said:
28th Feb, 2014 at 09:29:13am
Do the hubs need to be enlarged for the bearing?
28th Feb, 2014 at 09:54:47am
they're the same size, they fit just fine and are a fuckton cheaper. On 20th Oct, 2015 Tom Fenton said:
10021 Posts Member #: 1456 Mongo Barnsley, South Flatcapshire |
28th Feb, 2014 at 10:09:12am
What is the difference in them? Are they ball bearing instead of taper-roller? If something is worth doing, it's worth doing half of. |
28th Feb, 2014 at 10:24:24am
28th Feb, 2014 at 12:08:09pm
big balls...
Forum Mod 1927 Posts Member #: 1761 Stalker Bristol |
28th Feb, 2014 at 12:57:38pm
On 28th Feb, 2014 Nick warwick said:
big balls... I did think they had to bore the hub out for them to fit. The tapered type have a little spacer between them but it just seems to slide around! Is the race not in enough do you reckon? The spacer is there to stop the needle rollers getting crushed when you torque the hub nut up, but more importantly, to keep the inner races correctly spaced from the outer races on both sides. Edited by Carl S on 28th Feb, 2014. |
28th Feb, 2014 at 03:05:10pm
big balls... I did think they had to bore the hub out for them to fit. The tapered type have a little spacer between them but it just seems to slide around! Is the race not in enough do you reckon? The spacer is there to stop the needle rollers getting crushed when you torque the hub nut up, but more importantly, to keep the inner races correctly spaced from the outer races on both sides. So should this spacer be stuck between the two races and not move about as mine is? or will it only do that when the hub nut it tightened like you said? |
28th Feb, 2014 at 06:38:59pm
You'll see how it comes together when the CV is fitted.
Page: |
