Home > Wanted > wanted two mild sheet steel
kezzboycat
Member #: 10371
leicestershire
Ive decided to tub my arches so need some sheet metal needs to be a good length so its one peice and a good width size of the arche as ive had to cut quite alot out Thanks
i would go to your local steel stockolders off cuts are cheap as chips
You can buty it from B&Q, not the cheapest, but if you only want a but.
Otherwise, check out the metal supermarket.
kezzboycat
Member #: 10371
leicestershire
All sorted now thanks and couldn't get any off cuts the size I need
mini.cooper998
Member #: 3772
Wigan
easiest way is to buy a cheepo big bonnet from your local scrappies. Always cheep steel
I got a big sheet from my local body work/panel place.
Tomm
Member #: 1432
Kent
I work for a fabricating company, if you give me a rough idea of what size and thickness you need I will see what I've got stashed away.
