Home > A-Series EFI / Injection > Maestro Inlet Manifold
Tupers
Member #: 9441
South Devon
I've read a few threads on here about the benefits of long inlet manifolds and thought the one from my 1.3 Maestro engine might be good. Anyone ran one of these before or have any experience with long inlets of forced induction A-series lumps?
skolawn
Member #: 69
Coventry
I think the fact that the intake charge has to take a tight turn back on its self would negate any benefits..
I'd give it a go. Turning back on itself can't be much/any worse than what happens in the Metro turbo inlet.
deffo try it, maybe see if somone will whack it on a flow bench for a drink... robert?
The runners look like they have potential to be the basis of a plenum similar to the ones Paul S makes for his efi setup.
Robert don't drink lol.
id give it a go aswell
Daniel
Member #: 720
Gloucestershire
I have one, setup with injectors at the head face but haven't got round to running it yet. I'll dig out a few photos.
Edited by Daniel on 3rd Mar, 2014.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
looks grate t me
i thought about one of these back when i was going to go a-series and have 4 injectors stepped on the runners.
Tupers
Member #: 9441
South Devon
Thanks guys, to be honest I hadn't thought of getting it stuck on a flow bench.
I'll give my local guys a ring and see if they can do anything for me. I know it should be good in theory but I want a bit more solid info before I commit.
Don't waste money on a flow bench. The results will be meaningless. It's the extra length of the runner that will give you the extra mid-range torque.
Just make sure that it is clear of casting bumps.
What sort of bonnet would you use to hide it? It's gonna need a fair old bump in it.
I think you could get away without a bulge in the bonnet if the stubby Pico injectors were used, you could also turn the throttle body upside down and have the injectors in the bottom, space pending
The long runners will time the pulses to peak at the back of the inlet valve at overlap, promoting scavenging and improving VE.
Something I prepared a couple of years ago that shows the benefit:
Tupers
Member #: 9441
South Devon
With the fuel rail on top it only sits around 20MM above the height of the bonnet. I'll have a look at the Pico injectors as they might give enough clearance. If the injector block is flipped it all clears but is far too close to the manifold. Again this might be solved by a set of Pico injectors.
with the Pico injectors, the fuel rail will only be as close to the exhaust as the HIF44 was, but if you use a fuel return set up you'll get fresh cool fuel through the rail rather than it sitting there as it would in the HIF44. Still, i'd be tempted to make a heat shield for it :)
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
short injectors + heat shields?
