Home > Wanted > 1st motion shaft nut
madonminis
Member #: 9371
East Yorkshire
1st motion shaft nut needed
Or any nut the same thread before I buy one for silly £££'s.
Just need it to weld up a tool to remove the 1st motion shaft with my slide hammer.
Cheers fellas
Have you a pic of the one you need mate?
As I am sure I can sort you out
madonminis
Member #: 9371
East Yorkshire
Left hand nut is the 1"1/8 fitting on the 1st motion shaft, but the larger 1"1/2 nut from the other end is the same thread. Either would be a big help.
I have the big one here if that's any good to you?
madonminis
Member #: 9371
East Yorkshire
it sure is bud, you still got my address? Also what do you want for it?
I will pm you mate
