Home > For Sale > Lots of exciting bits
advantage998
Member #: 1840
Kings Lynn, Norfolk
SOLD
Edited by advantage998 on 16th Feb, 2014.
advantage998
Member #: 1840
Kings Lynn, Norfolk
BMW twin kam cnc machined inlet trumpets x 4, made to suit 8v conversion but should also fit 16v 40mm diameter 55mm long. £25 - Provisionally sold
BMW twin kam cnc machined inlet trumpets x 4 and plenum backing plate, made to suit 8v conversion but should also fit 16v trumpets 40mm diameter, 55mm long, 75mm spacing. £35
Early specialist componets twin kam cylinder head water outlet. One of the last ones they made before they machined them from billet. £15
PM Re 2056
Edited by John on 7th Feb, 2014.
advantage998
Member #: 1840
Kings Lynn, Norfolk
SOLD
Can I have a getors
adcyork
Member #: 6807
York
I'll have the emerald please. PM'd
Interested in the fuel pump and filter.
What is pump spec?
advantage998
Member #: 1840
Kings Lynn, Norfolk
Pump part no is OTP020, although its now fitted with a alloy AN fitting, the original steel banjo fitting is still included.
Will reply to PM's asap
also interested in the gt20 flanges if john isnt
advantage998
Member #: 1840
Kings Lynn, Norfolk
Maniflow twin box 1 7/8 twin box centre exit exhaust, a couple of bits of green paint scuffed. Brand new, £100
advantage998
Member #: 1840
Kings Lynn, Norfolk
Engine
1293cc Mini Twin Cam Engine
9.1:1 Compression ratio
BMW 8V fully refurbished head
Cam cover fitted with oil filler neck, shot blasted and painted
Modified fuel rail fitted with Aeroquip fittings
Brand new Bosch EV14 injectors (320cc/min)
Specialist components conversion kit
Dry decked – Machining by Specialist Components
Ferriday Engineering 1.6mm FSR Head gasket
Tuffrided lightened crank
Omega Forged Pistons
Lightened, balance and stress relieved rods
BMW under crown oil jets
Oil galleries machined for removable plugs
Centre main strap.
Arp Head studs, main bolts, rod bolts
DSN Classics Billet oil filter housing with turbo oil feed
Powerlite high torque starter motor
Specialist Components trigger wheel and sensor
Romac crank damper
SH Engineering 32mm water pump outlet
Dynamically balance crank, flywheel/clutch and crank pulley
Semi-completed inlet plenum
Brand new Jenvy throttle body
Gearbox
Quaife 2.877,1.827,1.329,1:1 Straight cut gearset
Quaife ATB Differential
Rebuilt with all new bearings, layshaft, bulk rings, gaskets
Brand new Pot Joints
Minispares Evolution straight cut drop gears
Grey Diaphragm
AP Racing Road/Rally performance clutch plate
Minispares ultralight flywheel and backplate
New slave cylinder, arm, push rod, release bearing shaft and bearing
Vented clutch cover
£5500 ono
Edited by advantage998 on 7th Feb, 2014.
PM'd re Mirror
Want that gearset!
On 7th Feb, 2014 John said:
Want that gearset!
Seconded
I phoned quaife already knowing the answer I'd get.................. Speak to Swiftune.......... but we've not made any of those in some time.
Edited by Sprocket on 7th Feb, 2014.
maccamcvey
Member #: 6673
Worral Sheffield
hi I would take the starter motor if you split the engine
eden7842
Member #: 8852
leicestershire
Pm'd for mirror
On 8th Feb, 2014 eden7842 said:
Pm'd for mirror
It's already spoken for *tongue*
eden7842
Member #: 8852
leicestershire
Damm missed that!
Louise
Member #: 10756
suffolk
hey that long racing mirror is cool haven't seen one like that only the 5 separate mirrored ones.
Hannah Louise :) Mini Girl
philc
Member #: 1346
bromsgrove
are you looking at splitting the engine?
advantage998
Member #: 1840
Kings Lynn, Norfolk
Wasn't looking at splitting the engine just yet, will keep you posted. What bit are you after?
I'd take the filter housing if you do split.
Phil.
advantage998
Member #: 1840
Kings Lynn, Norfolk
SOLD
man that looks like stiff suspension....
shame you're selling it looks a great project...
APS
Member #: 10369
Pickering, North Yorkshire
Are the rear quarters rubbers fixed or opening? If fixed, I'll have the set please :)
Edit: and if you decide to split the sub frames, it would be interested in the minifins, the hub quadrants and some of the braided cables
Edited by APS on 9th Feb, 2014.
www.apsbikes.co.uk
