Page: |
Home > Beginners Tech > How to switch on the electric fan when the car to hot | |||||||
11 Posts Member #: 10667 Member |
21st Jan, 2014 at 07:03:29pm
Hi need some help , running metro turbo engine in mini , fitted a Eletric fan in the inner wing where do i iput the switch to turn it on and what sensor do i need ,is there one built into the turbo lump some where or ready ?? What do I need any advice welcome . Alex |
3329 Posts Member #: 184 Senior Member Melton Mowbray, Pie Country |
21st Jan, 2014 at 07:07:27pm
Most rads with fans have a built in temp switch boss. The standard mini rad doesn't if you buy the really late mini rad it does have a boss for a switch.
http://www.twin-turbo.co.uk
21st Jan, 2014 at 07:19:25pm
Have a new mini spares rad part c / ARA 4442 ? What switch / sensor do I need ? |
21st Jan, 2014 at 07:20:48pm
Not using ecu |
21st Jan, 2014 at 07:20:50pm
Not using ecu |
22nd Jan, 2014 at 11:30:37am
if the electric fan is supplementary u could drill the thermo houseing if its a small sender check first |
830 Posts Member #: 908 Post Whore gateshead |
22nd Jan, 2014 at 12:31:00pm
just wire a switch to the dashboard.
balls to the blower!!!
2094 Posts Member #: 9894 Post Whore Dorking |
22nd Jan, 2014 at 12:48:06pm
Most don't bother with a sensor for an extra fan. If its getting hot in traffic just a switch in the dash should be ok and keep your eye on the temps. |
23rd Jan, 2014 at 08:52:42am
so long as you dont forget to turn it on of course |
23rd Jan, 2014 at 02:03:54pm
I'd be surprised if there is a modified mini owner who doesn't stare at the temps in traffic! |
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
23rd Jan, 2014 at 02:25:35pm
Even pretty unmodified ones do that too haha.
Edited by Carlzilla on 23rd Jan, 2014. On 26th Jan, 2012 Tom Fenton said:
24th Jan, 2014 at 08:24:09am
to be honest id not bother with running wires inside the car, just use a temp switch like the link perhaps use the coolant drain plug for the sender/switch
Page: |
