Home > Non-Mini Discussion > What's size do I need.
I am looking for a chuck to fit this for drilling.
It's 18mm hole
1mt, 2mt, 3mt ??
Edited by madmk1 on 25th Dec, 2013.
Simon, you need to put vernia calliper across the dia of the hole in the tailstck,
carl
oli79
Member #: 8480
Obviously check as Carl has said above, but if that's one of the 14 inch Chinese mini lathes they are all the same at mt2, which is around 17.7mm at the thickest end
http://www.amadeal.co.uk/acatalog/Tailstock_Chuck.html
Edited by oli79 on 26th Dec, 2013.
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
WHAT SIZE DO I NEED ?. . . . I would say 10" so the girls all told me. ..lol
That looks the same size as mine, if so it's mt2. It's worth buying an mt2 to mt1 adaptor too.
Is this any use to you lot? Just so you boys know, I don't know any thing about lathes apart from bolt can fly if you have not clamped them right. Also if the tool comes in to contact with the spinny bit, bad things happen lol.
Edited by madmk1 on 26th Dec, 2013.
What lathe is it?
Here you go mate, it has no make on it.
I'm 90% certain that its an mt2 you need. Mt3 is massive, usually on drills 20mm+ in size and mt1 only goes up to drills about 10mm.
My lathe is a similar size 350mm between centres and uses an mt2 taper. I'll have a measure of my tailstock tomorrow and let you know for sure what the ID is of the taper.
Mine measured 17.6mm and is an mt2, so I would say yours is the same size.
Thanks mate, that's a lot of help!
