Page: |
Home > Show Us Yours! > Craig's mini engine Re-build. 1380 NA this time! | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
26th Nov, 2013 at 09:30:31pm
Hello again TM'ers, so its been a while since I have been active on here.
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
869 Posts Member #: 2443 Post Whore Cheshire |
26th Nov, 2013 at 09:48:41pm
Good luck with it |
26th Nov, 2013 at 10:07:18pm
26th Nov, 2013 at 10:36:49pm
Tenner on it that by the time it's back in you will be looking to whack a turbo on it.......just don't look at anybody else's build threads or you will be sucked in! |
26th Nov, 2013 at 10:48:36pm
haha, we will see. I always wanted a b18c4 powered mini, I built the turbo engine as a 'cheap power upgrade to last me till I could afford the honda build' It ended up costing me the same as the honda lol.
6729 Posts Member #: 618 Post Whore Glasgow |
27th Nov, 2013 at 08:16:16am
good to see you back. pity your dropping the Turbo power but I can understand why you've gone down that route. |
27th Nov, 2013 at 08:28:38am
On 27th Nov, 2013 Rob Gavin said:
good to see you back. pity your dropping the Turbo power but I can understand why you've gone down that route. On 10th Mar, 2012 theoneeyedlizard said:
1425 Posts Member #: 9199 Post Whore Lancashire |
27th Nov, 2013 at 08:29:10am
pitty about the turbo build, should see good power from the motor you have there and should be able to use most of it too.
178 Posts Member #: 10196 Advanced Member |
27th Nov, 2013 at 09:10:41am
Good look mate not tempted with the stage 3 manifold?
27th Nov, 2013 at 10:12:25am
i run a 45 on my mini and was choked down to 38mm
On 27th Nov, 2013 Cables69 said:
Good look mate not tempted with the stage 3 manifold? Lol the weber says it a 48 on it What the mind can conceive the mini can achieve
27th Nov, 2013 at 10:28:23am
good luck. shame about the turbo. the plan for me for a series turbo was a cheap power ubgrade intil I went with a b18 type r lump. got most of the parts here for that.
27th Nov, 2013 at 07:56:00pm
Its actually been stamped twice, one of them is 45dcoe and the other I think is 48dcoe but looks more like 40dcoe.
Good look mate not tempted with the stage 3 manifold? Lol the weber says it a 48 on it yeah this one is chocked down to 40mm On 27th Nov, 2013 lee.pb said:
i run a 45 on my mini and was choked down to 38mm On 27th Nov, 2013 Cables69 said: Good look mate not tempted with the stage 3 manifold? Lol the weber says it a 48 on it We will see mate, Ill definitely want to give it a go to compare the two, but Ill probably end up buying another mini to do the honda conversion on lol. On 27th Nov, 2013 welshdan said:
good luck. shame about the turbo. the plan for me for a series turbo was a cheap power ubgrade intil I went with a b18 type r lump. got most of the parts here for that. but.... once you eventually do go turbo a series you will never go back I built a cheap as chips motor to start with, to make sure I could get it all to go, and to keep within a low budget for the car build. then built a more powerful motor (still on a budget). needless to say I can never see me using the Honda stuff! this might be the ideal stop gap to get the car up and running, as said, you will feel the need to turbo eventually! time is the best thing with a turbo build, if you gather the parts over a long period there are some great bargains to be had! good luck On 10th Mar, 2012 theoneeyedlizard said:
27th Nov, 2013 at 08:11:02pm
So the cleaning processes completed and this is how the weber came out:
27th Nov, 2013 at 08:18:23pm
If you do it, they are a work of art, but make nearly every job in that area a pita, I've got 10mm clearance to the bulkhead on mine |
27th Nov, 2013 at 08:32:10pm
i must admit i'm going to miss my weber but turbo is calling my name.
27th Nov, 2013 at 08:38:15pm
We will see how this one runs, but its going to be using the aldon yellow dizzy map enless I can find the red dizzy map lol
27th Nov, 2013 at 09:01:27pm
mine was running a standard electronic dizzy before converting to MJ. you should see about 100 bannana's which is good for a n/a
Forum Mod 5933 Posts Member #: 784 9 times Avon Park Class C winner Milton Keynes |
27th Nov, 2013 at 09:36:15pm
You measured the wrong end of the Weber, check the butterfly end, I reckon its a 45 I seriously doubt it! |
27th Nov, 2013 at 10:06:55pm
I second this as you can also see it says 45doce on the top plate.
On 27th Nov, 2013 paul wiginton said:
You measured the wrong end of the Weber, check the butterfly end, I reckon its a 45 Drives
28th Nov, 2013 at 09:09:35am
I measured both it is 48 on each, its been stamped on the top twice as well, will give it another go when its out of the petrol :) On 10th Mar, 2012 theoneeyedlizard said:
10th Dec, 2013 at 06:21:03pm
So finally got the weber finished and back together:
Edited by Craigie-B on 10th Dec, 2013. On 10th Mar, 2012 theoneeyedlizard said:
7763 Posts Member #: 74 I pick holes in everything.. Chief ancient post excavator |
11th Dec, 2013 at 08:59:08am
If it really is a 48, that's a lot of work on something that's totally useless for your engine...... On 13th Jul, 2012 Ben H said:
11th Dec, 2013 at 09:13:39am
I assume your not looking at running the choke mechanisum?
11th Dec, 2013 at 10:21:00am
are you planing to rev the nuts of this thing?
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
11th Dec, 2013 at 10:25:50am
im loving that DIY sandblast cabinet! On 26th Jan, 2012 Tom Fenton said:
Page: |
