Home > For Sale > Turbo Bits! - Morspeed/benross Turbo Head, Gt1752&t3 Turbos, Carbs, Manifolds And More!
TrialsLife
Member #: 6752
Caerphilly, South Wales / Plymouth
A load of turbo bits I no longer need.
Parts can be collected either from home in Caerphilly, South Wales, or from my work in Plymouth. Can ship anywhere but am only able to dispatch on weekends as that is the only time I am home.
Morspeed - Booster Super Squish 4 Cylinder Head - As new since last refurbish
Stamped MSPD 132, this cylinder head came with the following specs;
28cc Combustion chamber
36mm Inlet valves
30mm Exhaust valves
Fully ported and polished
180 pound double valve springs
Sent to Benross for refurbishment last year and had the following done;
Exhaust seats re-cut and new 21 4N stainless race exhaust valves fitted
New 180 pound double valve springs fitted
Fitted Hasteloyd super alloy inner spring locaters
Fitted new dupont hi spec stem seals
Fitted a new temp sender painted the head as well.
Fitted stellite hardend inserts in the exhausts
The head has never been fitted since being refurbished.
Was told by Benross that this head was easily capable of 200bhp+
Looking for £490
Garrett GT1752 Turbo, AR 53
Excessive lateral and axial pay, damage to compressor. Only really suitable for spares, or possibly repair.
£50
Garrett T3 Turbo, AR 42
Everything except for the exhaust housing is in good condition. No lateral play, but around 1mm axial play.
The plan for this turbo, was to combine it with the exhaust housing with the other T3 listed below to make a usable T3
£50
Garrett T3 Turbo
Damage to compressor, shaft is seized.
£20
Metro Turbo inlet manifold, good condition.
£45
Metro Turbo inlet manifold, good condition but no water pipes present
£40
Metro Turbo, T3 Exhaust Manifold
Apart from needing a clean up it is in good condition.
£35
K&N Cone Filter, Brand new.
£20
Ford RS Turbo Intercooler
£25
Edited by TrialsLife on 18th Dec, 2013.
lee.pb
Member #: 9199
Lancashire
pm'd turbo box
lee.pb
Member #: 9199
Lancashire
hi, awaiting payment details for turbo box
vegar
Member #: 189
What size is that k&n filter??
www.shag.no
TrialsLife
Member #: 6752
PM sent Lee
I will find out the size when I am home on Saturday Vegas.
Edited by TrialsLife on 27th Nov, 2013.
Cybertjuh
Member #: 10689
Heinenoord, The netherlands
Pm about the cilinderhead.
100ev8
Member #: 9138
wolves
any silicone boost hoses lurking about there ?
Edited by 100ev8 on 5th Dec, 2013.
http://www.fishfight.net/
jamestar
Member #: 9159
Devon
£20 for the knackered gt17??
Jawd
Member #: 10212
Sleaford Lincolnshire
Pm'd for the good garret GT1752
TrialsLife
Member #: 6752
PM's sent.
Sorry 100ev8, no hoses I'm afraid.
TrialsLife
Member #: 6752
I have removed all of the items that have been sold. All parts listed still up for grabs.
