Page: |
Home > Technical Chat > Convert MJ TPS to MAP | |||||||
1425 Posts Member #: 9199 Post Whore Lancashire |
20th Nov, 2013 at 08:46:13am
Been asked on an PM by Jonny F about how to convert the MJ TPS to a MAP.
Edited by lee.pb on 24th Nov, 2013. What the mind can conceive the mini can achieve
2094 Posts Member #: 9894 Post Whore Dorking |
23rd Nov, 2013 at 10:25:47pm
Thanks Lee
24th Nov, 2013 at 09:50:26am
Hi Jonny,
On 23rd Nov, 2013 jonny f said:
Thanks Lee I can't see the image though? cheers What the mind can conceive the mini can achieve
40 Posts Member #: 10334 Member Staffordshire |
8th Dec, 2013 at 11:36:23pm
Hi what value map sensor should i use and would you have any part numbers? Regards |
9th Dec, 2013 at 07:37:14am
http://uk.rs-online.com/web/p/products/719...CFTDMtAodizUAgg
On 8th Dec, 2013 tomostrash said:
Hi what value map sensor should i use and would you have any part numbers? Regards What the mind can conceive the mini can achieve
9th Dec, 2013 at 07:57:26pm
Many thanks for your help lee.kind regards |
9th Dec, 2013 at 08:53:29pm
On 9th Dec, 2013 tomostrash said:
Many thanks for your help lee.kind regards What the mind can conceive the mini can achieve
25th Dec, 2013 at 11:21:14pm
I now have most parts sorted but what voltage capacitor sound i use . Thanks |
26th Dec, 2013 at 08:51:20am
I have a load of the caps if you need a couple.
On 9th Dec, 2013 lee.pb said:
Got 18 caps and 4 resistors if you PM us your address i'll drop them in the post. On 9th Dec, 2013 tomostrash said: Many thanks for your help lee.kind regards What the mind can conceive the mini can achieve
1750 Posts Member #: 10190 Post Whore belgium |
20th Jan, 2016 at 10:13:55am
hy. old tread i know but no need to make a new one when things are so nice explained.
Page: |
