Home > Wanted > straight cut box/ gearset and drops
as the title suggests!
need them for the metro engine build; a bit skint at the moment so going to be cheeky and look for something cheap. Don't mind something needing re-building or some replacement bits
cheers
Rob
welshdan
Member #: 1111
s wales
Hi rob, not sure if you can stretch to new but the min-its tranx clubman set was always good value
Dan, i've spied it but would rather see if i could get something a bit cheaper to be honest
