Home > Wanted > wide array of engine bits and bobs
MINIMON
Member #: 863
Lathom, lancs
Hi all,
I'm after the following parts if anyone has anything?
Verto clutch plunger
Verto slave cylinder mounting bracket
Verto clutch arm
Metro thermostat housing (top cap not the lower sandwich plate)
Metro radiator (good condition)
Used (for parts) LCB (large bore)
2x 13 row oil coolers
List will be updated as I think of any more bits and bobs.
I'm based in Lathom, Lancashire. Parts ideally posted but certain items could be collected if local.
Thanks,
Ben
lee.pb
Member #: 9199
Lancashire
pm'd
MINIMON
Member #: 863
Lathom, lancs
Cheers Lee, PM replied to.
Also to add:
1x metro sandwich housing for thermostat
Wiring advice on secondary engine loom (pm based help if possible)
