Page: |
Home > 998cc > Stateside 998 Build Thread With Updates! | |||||||
168 Posts Member #: 10666 Advanced Member California, USA |
15th Nov, 2013 at 02:42:48pm
Hi All,
Edited by seahuston on 19th Jul, 2015. |
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
15th Nov, 2013 at 03:05:28pm
It all sounds fairly sensible.
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
15th Nov, 2013 at 04:17:32pm
Thanks for the heads up. Glad I'm at least started out on the right track.
2057 Posts Member #: 9252 Post Whore Cleethorpes |
15th Nov, 2013 at 04:27:18pm
have a look at this site it may help out with a few questions http://www.turbo-mini.com/62147.html Done now needs redoing lol |
15th Nov, 2013 at 04:36:04pm
I would say leave it at std bore size if you can, the std 998 flat tops are sturdy, (ok for 15-20psi) if you are looking for extra capacity then you may as well go for a 1275 rather than start boring IMO.
9812 Posts Member #: 332 Resident Cylinder Head Modifier Mitsi Evo 7, 911, Cossie. & all the chavs ...... won no problem |
15th Nov, 2013 at 05:10:44pm
Hi there,, if you want any parts or help from the UK drop me a PM
15th Nov, 2013 at 09:48:27pm
I have enough bits and bobs for a HIF44T to be assembled from (standard metro turbo fitment). I also have a plenum, and a spare Manifold, and am in custody of a new and un-used GT15 that the owner wants me to sell.
Edited by TurboDave16V on 15th Nov, 2013. On 17th Nov, 2014 Tom Fenton said:
16th Nov, 2013 at 10:27:45pm
TurboDave: PM sent. Thanks!
19th Nov, 2013 at 09:36:05pm
Came back from the machine shop today and am a bit discouraged with the scope of work/shape of the engine.
20th Nov, 2013 at 07:21:38pm
I pay about £10 per journal for grinding in the UK. On 11th Feb, 2015 robert said:
23rd Nov, 2013 at 12:11:35am
Back at it:
23rd Nov, 2013 at 02:43:36am
I'd definately start the search on a 12G295. Check on the minimania forum, to see if anyone there has one. For what you are after, a 12G295 would be pretty much ideal I'd have thought.
23rd Nov, 2013 at 09:47:06am
Don't forget, assuming it hasn't been wildly skimmed, the 940 will go out to 28cc. On 11th Feb, 2015 robert said:
4625 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
23rd Nov, 2013 at 11:57:40am
On 23rd Nov, 2013 apbellamy said:
Don't forget, assuming it hasn't been wildly skimmed, the 940 will go out to 28cc. Yes, but on a 998 overhangs the bores quite dramatically. Phil. |
23rd Nov, 2013 at 04:56:57pm
295 is the way to go.
25th Nov, 2013 at 02:06:23pm
Roger that, looks like the 295 is the next step. |
4th Feb, 2014 at 02:46:24pm
(I'm not dead yet!)
4th Feb, 2014 at 06:59:14pm
6th Feb, 2014 at 04:48:38pm
Roger that, I've read that is the best cam for the engine and starting up the hunt. I guess my major question was how much difference it will make? It seems though, that it may be one of those, "do it right first" kind of things that I should just replace it and be done.
Edited by seahuston on 6th Feb, 2014. |
6th Feb, 2014 at 05:17:55pm
The MG is a good cam but the best cam is the MD274. 112 LSA is an obvious improvement over the MG at 107.5. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Feb, 2014 at 05:20:55pm
Thanks all for the advice. Roger that on the MD274 cam, sounds like a worthy upgrade coming from the "Factors affecting performance" thread.
Edited by seahuston on 9th Feb, 2014. |
4890 Posts Member #: 1775 Post Whore Chester |
9th Feb, 2014 at 06:46:00pm
I used a iwis simplex chain.
9th Feb, 2014 at 07:13:25pm
I'm not sure anyone makes performance 998 A+ main bearings anymore.
Edited by Paul S on 9th Feb, 2014. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
1043 Posts Member #: 10424 Post Whore Swansea boyo! |
9th Feb, 2014 at 07:27:30pm
Wish I'd looked at this sooner! Lots of helpful stuff for doing a 998, will be following this one (:. Must suck that there aren't many parts around! Edited by Shauna on 9th Feb, 2014. They don't die, they just get faster! |
9th Feb, 2014 at 07:47:55pm
Paul:
Page: |
