Home > For Sale > Refurbished Stage 3 Forced Induction 1275 head
Based on an MED Stage 3 Head with 36mm inlet and 31mm exhaust valves.
New bronze valve guides fitted and reamed to size.
Valves lapped in and new viton valve seals fitted to all 8 valves.
New double valve springs fitted with locating rings to ensure the inner springs don't move and bind.
Chambers opened to 28cc. Following that the head had a light skim to ensure flatness. This reduced the chambers to 27.8cc. The previous work was completed by Benross to his usual high standard.
Force racing dry deck port fitted with a spare port supplied for the engine end. This has been notched to clear a DSN engine steady.
New coolant sensor fitted and all threads chased out with the correct taps. Painted black as all the fasted engines are black.
I ran the head for approximately 5 minutes, only to find that no 6 push rod hole had broken through to the inlet port. The hole has been sleeved to resolve this.
£400 + £10 P+P, insurance can be added at your cost.
I am only selling as I can't be bothered to swap the head over for the one I borrowed from John.
Bump
Such great head you have to give there Andy!
So your Dad tells me.
That's weird.....
What are people's opinions? Is the price miles out or just the wrong time of year to sell?
It's effectively a brand new head so I don't think the price is a problem Andy, may be the sleeve putting people off? Could also be the time of year like you said.
dev 11
Member #: 9393
stoke on trent
Time of year id.imagine mate itd be perfect for.mw but too many spends this month!
I think its just time of the year. I'd pay that sort of money for the right head, bearing in mind what it wold cost to get a fresh one done.
lee.pb
Member #: 9199
Lancashire
Heads a bargain, as its over £600 to get one done.
Time of year for sure.
welshdan
Member #: 1111
s wales
Im suprised you still have this. Its a lot of head for the money. With some omega cast pistons and the right parts this could make a very powerful engine on a very reasonable budget
Sold. *smiley*
