Page: |
Home > A-Series EFI / Injection > Fuel and Return Help | |||||||
186 Posts Member #: 7637 Advanced Member Fremont California |
1st Nov, 2013 at 05:43:35pm
My self perceived abilities exceed my capabilities.
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
1st Nov, 2013 at 05:46:21pm
Why not braise 90 degree unions in to form the bends? On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
3588 Posts Member #: 655 Post Whore Northern Ireland |
1st Nov, 2013 at 06:24:07pm
What is the actual problem ? and are you using a suitable pipe bender ? 9.85 @ 145mph
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
1st Nov, 2013 at 07:01:31pm
If the pipe is standard central heating microbore (8mm in the UK) then I would use soldered elbows instead of trying to bend the pipe,pretty much as Andy suggested. |
1st Nov, 2013 at 10:08:57pm
I have a good bender, it is my accurate bending skills that are weak. Keeping the tubes parallel and with the correct radius bends through the whole run was the problem. To really keep them parallel you need slightly different radii for the inside and outside bends.
1st Nov, 2013 at 10:10:50pm
Actually the 90's made with the bender are quite good, just my placement of the start of the bend is off. |
1st Nov, 2013 at 10:18:43pm
On another side note...anyone know what the hole in the heel board is? Just to the left of the tubes... |
1st Nov, 2013 at 10:36:03pm
I guess patience and practise as to where the bends end up.
2nd Nov, 2013 at 04:23:06am
The trick to ensure the radius of the bend fits between the subframe and heelboard/floor without being too low is to replicate the factory run in so much as it turns 90 degrees out towards the side of the shell before doing the 90 degrees upwards.
2nd Nov, 2013 at 04:48:58pm
Thanks everyone!
2nd Nov, 2013 at 04:50:08pm
Oh and I tried this in stainless first a few months back and that was a total failure.
2nd Nov, 2013 at 05:33:02pm
On 2nd Nov, 2013 tmsmini said:
Oh and I tried this in stainless first a few months back and that was a total failure. There is post somewhere I made mine in stainless, and it worked out good. What went wrong with yours? Edited by TurboDave16V on 2nd Nov, 2013. On 17th Nov, 2014 Tom Fenton said:
2nd Nov, 2013 at 08:29:05pm
Stainless was harder to bend for me than the copper nickel and I could not keep the radius correct at all after a couple of bends. Any of them would work Ok for a single line but not the pair.
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
2nd Nov, 2013 at 08:37:30pm
Oh.... uh oh... I've just mounted my rear subframe and didn't even think of the fuel lines... will I be able to put the lines in without removing the subframe again?
3rd Nov, 2013 at 08:43:44am
On 2nd Nov, 2013 evad1980 said:
... will I be able to put the lines in without removing the subframe again? Not without extreme difficulty or a join nearby. As the pipe(s) have to turn 90 degrees backwards over the top of the subframe, the only way to feed the pipe(s) inbetween the subframe and shell would be to hold them 90 degrees out to feed them in then rotate them once over the top of the subframe. With a full length of pipe I wouldn't even try unless the shell was on its side. And personally I wouldn't want a join on the run(s) under the floor pan, unless it was a well soldered "end feed" fittting (which adds virtually nothing to the overall diameter), as any "easy" join (compression fittings, hose/clips etc.) are vulnerable to speed bumps, kerbs etc. Equally I wouldn't run the pipe(s) over the subframe (the easy option) for the same reason, behind the subframe gives them a good measure of protection. The last two points are just my opinion, but I'm running much higher pressures with EFi than the average setup with an SU. Schrödinger's cat - so which one am I ??? |
3rd Nov, 2013 at 02:46:15pm
Bollocks! In my 'keenness' to get the subframe on to have a look I completely overlooked the fuel lines.... Not that it's a major fook up, just don't fancy doing it again.
3rd Nov, 2013 at 06:15:53pm
I don't look at it as a thread hijack at all, just contributing to the general knowledge.
4th Nov, 2013 at 11:04:28am
Indeed!! |
14th Nov, 2013 at 04:06:54pm
This forum saved me from making another mistake as I was ready to take it all out and start over or have some one else do it.
73 Posts Member #: 10315 Advanced Member |
15th Nov, 2013 at 11:25:41am
I think you've done a great job. It's not easy getting them perfect like the factory ones. I ran 3 lines and had tried to get them all lined up and it turned out ok bit definitely not perfect.
1425 Posts Member #: 9199 Post Whore Lancashire |
15th Nov, 2013 at 11:55:59am
Had thre fun of making lines on my mini a couple of years ago.
Page: |
