Home > For Sale > clearout of a lot of mini/metro turbo engine parts, cheap prices
welshdan
Member #: 1111
s wales
I am a hoarder of mini parts (aren't we all?). I have this lot up for sale, in reality I will probably never end up using any of it. Items are reasonably priced, collection preferred from np4, but will post at buyers expense
T3 oil drain. Good order. I think this came off a ford t3, but will fit the metro T3, though the pipe may need shortening. £5
Metro turbo head 1. This came with a load of parts when I picked up a couple of turbo motors. i was told that it came from a gold seal engine. Sadly someone has removed 3 of the exhaust valves. A good genuine turbo casting though £sold
Unknown ?performance exhaust manifold. This also came wit engine parts that I bought a while ago. £10, now confirmed as an mg metro item, good upgrade over the standard mini exhaust. cheap
A+ Rockers. Removed from a Metro Turbo motor. £15
Oil Filter housing £5
Oil filter housing 2 £sold
Metro thermostat housing. Removed from an MG metro motor. £10
MG metro camshaft. Came out of a metty turbo lump. Some surface rust but could clean up fine £sold
Alternator 1, spins free. £15
Alternator 2, also spins without problems £15
Coil, including bracket £10
1275 dizzy x2. these came with a pair of MG metro turbo engines, but am unable to confirm if its an original turbo item. cast into the body is LUCAS 54403817, with 84193A, 4884 and 1185 to the plastic module respectively. if anyone can help to id these please let me know.
£10 each
T3 metro turbo exhaust elbow £sold
Bolts and metal gasket for above £sold
Servo Bracket £5
MG metro turbo throttle abutment plate £sold
?MG metro turbo plastic carb/ manifold spacer £6
Metro turbo inlet manifold. in good order, water pipes uncut, £sold
?Hiff 44, on a water heated inlet manifold. £sold
Starter motor, £15
Turbo fuel pressure regulator, can include pipes, bracket etc £sold
Fuel pump, £5
Driveshafts, look to be straight, not sure if off a metro or mini £10
Duplex pulley, as shown £4
Cooper sport camshaft £20
used Duplex timing chain. Links E marked £10
water pump and pulley £5
MG metro turbo head, complete. part no stamped behind the thermostat housing. double valve springs. Looks to either be a very early head, or has had the guides done at some point as it does not have sodium filled valves. it was removed from a genuine turbo motor engine no 12HC16AA. £80
awaiting payment and collection on this so might be gone
Pushrods, a bit rusty but could clean up, £5
That's about it for now, though I am slowly sorting my way through parts that I no longer require.
Pm me if you need any extra info, cheers, dan
Edited by welshdan on 29th Nov, 2013.
This:
looks like a standard MG Metro manifold and down pipe.
welshdan
Member #: 1111
s wales
cheers, im happy to go with that.
welshdan
Member #: 1111
s wales
have been told that the carb/manifold are mg metro items too. cheers
welshdan
Member #: 1111
s wales
Dizzys a tenner each.
Open to offers
welshdan
Member #: 1111
s wales
just added a couple of other items that I have found
unused enamel downton badge, £sold
large 'mini' sticker, as fitted to the 90s rover works cars, red, £10
mpi clock loom, £sold
stainless 'G' from GB badge, might be of use to someone, £2
cheers, dan
welshdan
Member #: 1111
s wales
updated some items sold. still have some useful parts here. open to offers
Nick
Member #: 154
Midlands
£15 posted on the rusty cam?
welshdan
Member #: 1111
s wales
go on then nick, pm sent.
would rather this stuff used than scrapped
cheers, dan
welshdan
Member #: 1111
s wales
few more bits gone - head 1 with missing valves, thermostat housing, oil filter housing 1, downton badge.
open to offers on the rest, cheers
the gavner
Member #: 10684
Hi do you still have the exhaust manifold? Cheers.
welshdan
Member #: 1111
s wales
yes, pm sent
lee.pb
Member #: 9199
Lancashire
£5 posted for oil drain ?
