Page: |
Home > 998cc > 998 turbo. what oil pump do i use? | |||||||
40 Posts Member #: 10537 Member |
22nd Oct, 2013 at 01:12:35pm
Hi. Im new to the turbo scene so looking for as much advise and help as possible!
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
22nd Oct, 2013 at 01:31:13pm
Read:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
22nd Oct, 2013 at 01:57:59pm
Thanks. Although i have already looked on there and around this forum but cant find what im looking for |
22nd Oct, 2013 at 02:42:58pm
You have two options:
22nd Oct, 2013 at 03:02:34pm
Thanks for the reply paul :) would a good 998 punp be up to the job? Or is the extra effort alot more worth while. What do you think about fitting a centre main strap? And standard internals for 120bhp. If even possible?? Thanks. Rob |
22nd Oct, 2013 at 03:17:41pm
Personally, I would not use standard pistons on 15psi boost. I use the Hypatec pistons in mine at 120hp.
22nd Oct, 2013 at 07:10:36pm
Ahh ok thats abit of a pain. What is the limit before upgraded internals are needed? I really want the engine to rev so know double valve springs will be needed. Whst else will i need to allow it to rev? I.e cam choice? I was looking at a cooper head but its out of my budget by the time i have it rebuild and convertes to unleaded :(
23rd Oct, 2013 at 08:56:01am
If you want revs and boost then you will need a strong bottom end and drivetrain.
Page: |
