Page: |
Home > A-Series EFI / Injection > Spark timing that hunts and drops out at idle and TPS that stops reading position | |||||||
11 Posts Member #: 10310 Member |
18th Oct, 2013 at 07:43:46pm
I am trying to sort out my Specialist Components Typhoon ECU/EFI setup for my K1100 head conversion and have some problems that are confusing. I have sent an email off to Simon at SC and he has been very helpful, but it's Friday and his local time is just before 9PM, so I don't expect him to reply before Monday next week.
There are two kinds of people in this world and I'm not sure you're one of them... |
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
18th Oct, 2013 at 07:58:09pm
Have you checked the configuration options to make sure the ECU is set for the correct TPS and CPS?
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
18th Oct, 2013 at 08:24:09pm
The ECU is set for the K1100 TPS and SC's crank sensor set up (36-1 Ford style trigger wheel). SC loaded a map that was specific to my engine. I do have the maps they make available online for download, but they don't match my set up as close as the original is supposed to. I'm kind of reluctant to change the map at this point as I really am new to this and don't want to mess it up even more! There are two kinds of people in this world and I'm not sure you're one of them... |
19th Oct, 2013 at 09:30:38am
16383 is 11111111111111 in binary so that is an error code of some sort. SC will be able to tell you.
3588 Posts Member #: 655 Post Whore Northern Ireland |
19th Oct, 2013 at 09:56:12am
Can you log the information ? Log then view in some sort of graph viewer, and you would be able to see any anomalies with any of the inputs, and also the timing the ecu is commanding.
19th Oct, 2013 at 10:09:55am
16383 deg (100000000000000 - 1 !)could also be the ECUs interpretation of -1 deg.
4890 Posts Member #: 1775 Post Whore Chester |
19th Oct, 2013 at 01:59:09pm
Have you reconfigured the ecu for the new tps? There is a procedure in the instructions on the software cd or web download, that get you to wsetup the voltage mine was miles out. I run a supercharger and I don't care the TB is on the wrong side.
21st Oct, 2013 at 07:18:17pm
After email with Simon at SC it turns out that most likely I have to turn the idle screw back to get the idle down to 1000 RPM and approximately 6 degrees of advance. It seems the ECU is retarding the spark to keep the idle down. I also am waiting to get a few connector contact pins and extraction tool so I can repair the 28AWG CAN Low wire that I pulled out of the connector while removing it to check connectivity between the TPS and the ECU. I should have known better to treat that connector with TLC as I used to work as a Manufacturing Engineer in the aerospace industry. Small wires don't take much load before they fail. There are two kinds of people in this world and I'm not sure you're one of them... |
11046 Posts Member #: 965 Post Whore Preston On The Brook |
22nd Oct, 2013 at 09:29:24pm
Four pin TPS as originally used on the BMW throttles?.................................
23rd Oct, 2013 at 05:32:48pm
oh, man I had forgotten that little detail. Sprox is right, three wire TPS is sweet and simple. On 17th Nov, 2014 Tom Fenton said:
23rd Oct, 2013 at 11:22:34pm
Well, I spent $175 on the new TPS so I'm going to stay with it at least until it breaks. The wire I broke is on the ECU connector end and allows the ECU and my laptop to talk to eachother. Still waiting for UPS to deliver the contact pins and extraction tool... Edited by CraigD on 23rd Oct, 2013. There are two kinds of people in this world and I'm not sure you're one of them... |
24th Oct, 2013 at 07:27:12am
Well ok but to get it to work somewhere near right in the first 2 to 3 degrees of rotation you'll need to remove the metal inserts from the scew lugs and file the holes a little longer. This will allow the sensor to measure throttle movement from idle but it measures less at full throttle which is less of a concern. The thing with that tps is that it is two sensors in one. A fine scale for the first 10 degrees off idle and a course scale for the cruse and full throttle. You can link the two together with some resistors but that changes the sensor characteristic which would not normally be an issue but if you are using a map that was calibrated to use just the corse scale it might need quite a bit of re calibration. On 26th Oct, 2004 TurboDave16v said:
9th Nov, 2013 at 02:03:21am
It's been a while since I was last here with my epic problems. Thanks for everyone who lent a hand with suggestions and such.
9th Nov, 2013 at 10:49:22am
Is the crank trigger a VR sensor ?
9th Nov, 2013 at 10:37:59pm
I have noticed (what I think) was some weird timing characteristics at cranking with the SC ECU, it appeared to me that the spark advance was 'scattered' during cranking, but that could just have been my missunderstanding. I never had any real time to confirm one way or the other, so i'm still unsure. On 26th Oct, 2004 TurboDave16v said:
9th Nov, 2013 at 11:57:15pm
The non-adjustable light I have is a very good quality light that has never been off in all the years I've had it. I recently set up timing with a Pertronix distributor on a '63 Chevy II wagon I had; it was dead on for that one. I've never seen an offset with any distributor before this.
10th Nov, 2013 at 12:50:41am
On 9th Nov, 2013 CraigD said:
The only thing I don't understand is how my timing light shows the spark about 25 degrees retarded when the ECU shows it at 6 degrees advanced at idle. I also bought a new timing light that allows me to dial in the advance, but it doesn't pick up enough of a high tension signal from the spark plug wires to fire the light. When I input a crank offset of 30 advance the ECU tries to retard the ignition (ends up somewhere around 1 degree advanced) and the engine speeds up like I would expect it to with advanced spark. It shouldn't be running retarded 25 degrees! It would be up to you the user/tuner to ensure that base timing via crank reference position is set before any tuning is done. That's basic setup. You need to determine and tell the ecu where the "missing tooth" occurs, in order for timing commanded on screen to reflect actual timing at the plug. If you're running a wasted spark setup ( ie crank trigger only and no dizzy ), dont bother with a dialback light. Just baseline with a fixed light. Wasted spark and dialback can only add confusion as it will display double actual rpm and double actual timing. 9.85 @ 145mph
10th Nov, 2013 at 10:56:03am
I also filed a bit more out of the TPS slots and made sure the minimum reading is in the fine resolution part of the range. It's running better than before. There is no fine resolution in the range of just the one sensor of the Bosch 0280 122 201 TPS On 24th Oct, 2013 Sprocket said:
it is two sensors in one. A fine scale for the first 10 degrees off idle and a course scale for the cruse and full throttle. You can link the two together with some resistors but that changes the sensor characteristic which would not normally be an issue but if you are using a map that was calibrated to use just the corse scale it might need quite a bit of re calibration. The four wire TPS Bosch part 0280 122 201 is two individual sensors in one package. The fine scale sensor is on pin 1, the coarse scale sensor is on pin 3. Negative is pin 4 and +5v is pin 2. In the Specialist components applications I have seen, they only use pin 2,3 and 4. The coarse scale sensor does not read angular movement much before ~15 degrees, and the fine scale sensor stops reading angular movement after ~25 degrees. Put simply, if you only use the coarse scale sensor, you need to adjust the fixed position of the sensor by elongating the mounting holes so that it will read angular moevemnt from a closed throttle. What this tends to do is reduce the angular reading at full throttle by ~15 degrees. This isn't too much of a problem depending on the engine and state of tune, you might in some circumstances see actual full trottle conditions start to go slightly lean. I'm happy that you're getting to the bottom of things. Edited by Sprocket on 10th Nov, 2013. On 26th Oct, 2004 TurboDave16v said:
Page: |
