Home > Wanted > Oil return casting and banjo bolt Turbo Metro
Roymck
Member #: 10601
Haslemere Surrey
Short on a couple of items for my turbo build up .
Need the Banjo bolt for the turbo oil feed pipe to block fitment .
Also for the oil return turbo to block there is a fitting that goes into the redundant mechanical fuel pump hole in block . Is it a alloy casting? not sure what it looks like .
Thanks Roy
Roymck
Member #: 10601
Haslemere Surrey
Come on lads , somebody must be able to help!!
DSN Classis do repro oil drains for the block
lee.pb
Member #: 9199
Lancashire
http://www.dsnclassics.co.uk/retrosport-sh...t-billet-alloy/
You won't find a banjo bolt that fits directly into the block as it's an NPT thread.
You'll need an adaptor or t piece if you want to Reston the original oil pressure warning swtch.
I have the s shaped block that bolts to a T3 turbo and the return plate that goes to the block, if they're the parts you're after?
Roymck
Member #: 10601
Haslemere Surrey
Matty Pm sent .. Otherwise need help here . How does the turbo feed oil pipe connect to the block and where . I have the oil pipe but cannot see how it connects up to the block . Does it piggy back onto the solid oil pipe to the oil filter?
Put a picture up of what you have got. If you are still using the old steel pipe from the metro,most people replace them with a braided hose.
