Page: |
Home > Beginners Tech > 1098 Injection Turbo Setup | |||||||
22 Posts Member #: 10615 Member Maryland, USA |
4th Oct, 2013 at 02:08:51pm
Hello guys, this will be my first post, and have been trying to formulate a plan for over the winter. Currently I am trying to wrap up my 61 Morris Minor I put a 95 Camaro v6 fuel injected engine in. Today hopefully will be it's 2nd time ever out of the garage. Anyway, so I have a 76 Clubman Estate with a 1098 in it, RHD. Engine/Gearbox is in excellent shape and I would like to leave it alone internally. I am installing a Specialist Components 5 Port Injection setup on a customers car and would like to go ahead and do one on mine. Being an Estate I was slightly concerned about fueling, I really did not want to do what I did in the Morris which is run a LP pump to a fuel accumulator then HP pump, but that seems to be the easiest way around that. I would like to do a remote turbo over the flywheel cover. Any suggestions into what turbo to look from to build boost early, since I am keeping motor stock, would keep the revs well under 6k. Basically I just want a fun little street car to poke around, nothing over the top, the Morris can handle that, and the Trabant can handle being the slowest car in the stable. I understand the 1098 has roughly 45bhp @ 5250rpm and 56lb ft @ 2,700rpm. Compression ratio of around 8.3:1/8.5:1 . What would be the threshold of trashing parts in stock form. Would like to see somewhere in the 70hp range.... Thanks guys for any suggestions/comments.
4th Oct, 2013 at 09:17:03pm
nice wagon
4890 Posts Member #: 1775 Post Whore Chester |
4th Oct, 2013 at 11:20:36pm
I like the look I run a supercharger and I don't care the TB is on the wrong side.
6745 Posts Member #: 828 Post Whore uranus |
5th Oct, 2013 at 06:02:40am
a gt15 garret , or a small ihi turbo , anything off a car that has the same sort of power your looing for really . I think you will easily hit 70 bhp , especially with a nice inj system you can map . Edited by robert on 5th Oct, 2013. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
5th Oct, 2013 at 07:32:06pm
That looks old skool as fuck. Love it |
7th Oct, 2013 at 03:22:33pm
I have built before a stock suzuki g10t and that used a IHI RHB31/32 turbocharger. Wonder how that would translate over to the 1098? The history of the car is good, had 20k original miles, mechanically in really great shape, welding was a little amateur, but not too bad I will revisit it maybe in the spring. I redid all suspension, brakes, etc, fabricated roof rack, dash, and many other things. Now I would like a small performance increase... something to tinker around with.
2406 Posts Member #: 341 aka T2clubby South Staffs |
7th Oct, 2013 at 04:31:12pm
Great looking car, what are the wheels? |
7th Oct, 2013 at 06:19:30pm
The wheels are 13x7 Aero Race Wheels Spun Formed. They were all chrome, and just painted the centers black. Still trying to fabric a center cap that is low profile. |
8th Oct, 2013 at 06:23:55pm
While I want to get the SC Injection kit, I am wondering if I could get away with a Hif38, or my buddy is offering me his WEBER 32/36 DGV... would this work with the turbo well? I see they have a nice turbo plenum for them as well available. Might run this for a year or so till I can spend the money on the SC setup.
538 Posts Member #: 9393 Use the search function before buying stuff from me... stoke on trent |
8th Oct, 2013 at 10:32:50pm
Mhmmm love that clock/speedo where is that from |
9th Oct, 2013 at 04:00:45am
i think almost any crab can be converted but the amount of things needed probably out weighs just getting the right one?
9th Oct, 2013 at 04:27:40pm
I dont understand what the problem is.
9th Oct, 2013 at 11:22:40pm
not saying it cant be done as it clearly can be..
1425 Posts Member #: 9199 Post Whore Lancashire |
10th Oct, 2013 at 07:15:14am
very neat setup
10th Oct, 2013 at 10:24:11am
On 9th Oct, 2013 notabmw1 said:
I dont understand what the problem is. The "problem" isn't a problem as such, it's just a complication. For a carb to work under boost pressure anywhere that pressure could leak out has to be sealed and, very specifically, the float chamber has to be pressurised to boost pressure (minimum) or the fuel simply isn't going to come out the jet(s) if the air passing over them is at a higher pressure than the fuel. Carbs work on pressure differences created by flow velocity through venturis. If the static pressures are different, it simply won't work. I can't remember where the float chamber vent is on a downdraught weber (years since I touched one) so maybe in your example piccys the big bit over the top does pressurise the float chamber but what about all the other places pressurised air (probably including vapourised fuel) could leak out, ie throttle spindle. Schrödinger's cat - so which one am I ??? |
14th Oct, 2013 at 04:00:00pm
Over this past weekend I went down to the Mini 54 and on Friday at the swap meet someone had a brand new Weber with Plenum, so I had to pick it up... Turbo should arrive tomorrow it looks like, and the rest of piecing it together continues.
14th Oct, 2013 at 07:12:40pm
nice job !
29th Oct, 2013 at 02:33:56pm
Well my buddy came over with his chevy sprint converted Mini and got to take if for a blast, and it pulled quite nicely. He donated a sprint intercooler with integrated BOV, some piping, 50mm aluminum radiator, and some other odds and ends. So now I am trying to figure out which distributor to go with, or how to set it up properly on a A-Series. After much research, I am wondering if I should go megajolt. Trying to keep it simple though, and cheap...
Edited by notabmw1 on 29th Oct, 2013. |
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
29th Oct, 2013 at 02:41:48pm
Megajolt is tried and tested. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
4th Nov, 2013 at 02:30:39pm
Well started in a few days ago, gonna have to put it on hold for a little bit, but I decided to cut the intake off the stock cast manifold and will use that to start from.
2057 Posts Member #: 9252 Post Whore Cleethorpes |
5th Nov, 2013 at 08:10:07am
weber dfid make some turbo carbs which is what i think you have pictured above as these were used to convert n/a cvh engines to turbo as a kit form and produced good results just that over here there very rare and so are spares for the carb. nice looking build keep up the good work Done now needs redoing lol |
Page: |
