Home > For Sale > Cobra classic buckets, intercoolers and wood and pickett arches
adamt
Member #: 9181
Rhoose, Cardiff
I have for sale a pair of cobra classics with headrests in good condition. Only slight damage to the piping caused by harnesses rubbing. £80 collected from near Cardiff, south Wales
Also have a ford escort rs intercooler with modified end tanks and a standard Toyota starlet intercooler, both ideal size for a mini. £30 each posted
Wood and Pickett arches painted black, In good condition. SOLD
Edited by adamt on 17th Oct, 2013.
My project Toyota powered mini: http://www.turbominis.co.uk/forums/index.p...tid=470448&fr=0
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
if only i could pick up those seats!
lockfast
Member #: 2775
Aberdeen
How wide are the arches?
adamt
Member #: 9181
Rhoose, Cardiff
They are 2.25 inches at the widest point
pooler70
Member #: 7657
Do you have pictures of the damage to the seats?
adamt
Member #: 9181
Rhoose, Cardiff
Here are some pictures of the damage to the piping. Just a bit behind the headrest where the harness went through and some on the sides of the seat. Not really that noticeable.
adamt
Member #: 9181
Rhoose, Cardiff
Bump
How do you fit those arches?
tempted.
adamt
Member #: 9181
Rhoose, Cardiff
Arches are fitted by screws or rivets on the underside that go into the seam. I have also on the two fronts made brackets so they can be bolted to the wing but these dont have to be used.
adamt
Member #: 9181
Rhoose, Cardiff
Arches now sold
