Page: |
Home > Non-Mini Discussion > 32-36 DGV webber on 2L HiLux | |||||||
30th Sep, 2013 at 09:57:29am
as above this is regarding my work ute a Toyota Hilux 2wd 5 speed manual fitted with a webber DVG 32-36 carb its a mechanical progressive two barrel carb
1st Oct, 2013 at 01:37:37am
well i found a few vacuum leaks some that i cant fix with out pulling the manifolds off
1st Oct, 2013 at 04:56:35am
ok i have reduced the vacuum leaks but its still giving me fluctuating wide band readings |
6th Oct, 2013 at 09:27:43am
right vacuum leaks fixed!!
Page: |
