Home > Wanted > Standard-ish 1275 head in good condition.
Nial
Member #: 9073
Edinburgh
I've got a standard 1275 Rio with 75K miles on the clock.
While pushing the car in gear to check tappet clearances I can hear compressed air escaping, I presume the valves/seats/guides are all completely knackered.
I have plans for an engine re-build but in the interim would like to get a better head on, so am looking for a standard-ish head in cood condition.
If anyone's got one they were thinking of getting modified I can swap a good condition 12G940
casting and some cash.
Thanks,
Nial.
lee.pb
Member #: 9199
Lancashire
hi nial, have a standard 12g940b
the only issue its a small valve, was removed off a mates mini when fitting his MED head.
can post some pictures
Get a compression test done, air will escape on any build engines dont hold air indefinately (sp?)
Nial
Member #: 9073
Edinburgh
Do you know what condition it's in?
How many miles were on the car when it was removed?
Thanks,
Nial
Nial
Member #: 9073
Edinburgh
I can easily push the car in third with the plugs in then hear any compressed air escaping over about
three seconds. I don't need to get a leakdown test done! *frown*
I'm planning a total rebuild over the next six months or so but a not completely shagged head
would be a good interim improvement (I hope).
Nial.
Andy500
Member #: 2443
Cheshire
Are you sure it's shagged and it is the head? Some compression noise is perfectly normal, or at least I always thought it was. If it was fucked then you probably wouldn't hear it escaping!
