Home > Good Garages & Parts Suppliers > Better Cooling
era mini mark
Member #: 10523
PALM BAY FLORIDA U S A
Ok here goes, can anyone tell me is it possible to reverse the rotation of the cooling fan. I was thinking this because I rode on a rocket ship, n I came up with the rocket scientist notion of hmmm, what if I can pull in cooler ambient air across the radiator ( 80-90 degrees ) vs 170 or higher under hood temperature that's typical under hood temp for a mini. if possible this would be real cool so to speak. anyone ?
When the car is moving the engine bay is at a high air pressure and the wings are at a low pressure so air will naturally get pulled through
Your idea may work when stationary but imo the front grill is not a millions miles from the radiator so it can get clean ish air anyway
Its much better to duckt the radiator to the inner wing so the air that passes through the radiator has no choice but to exit the engine bay
AWDmoke
Member #: 713
Western Australia
Short answer, NO.
The mechanical fan cannot be reversed.
An electric fan can be reversed, and will work the way you want - up until you drive the car forwards!
The grill is a high pressure area & the wheel arch is a low pressure area. The air will force against the flow of the fan, making the car run even hotter.
On 24th Dec, 2008 Nic said:
AWDmoke
Member #: 713
Western Australia
Oh, beaten to it by Brett!
*happy*
We said the same thing at least
Ben H
Member #: 184
Melton Mowbray, Pie Country
I agree that it is not an improvement, but the fan can be changed to pull instead of push. You would need a totally new fan with the blades at a different angle, but it could be done.
Short answer, NO.
Edited by Ben H on 29th Aug, 2013.
http://www.twin-turbo.co.uk
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
how about some vents in to the wheel arch the top arrows.. i got carried away with the rest of the crap lol edit ill be twisting that turbo to get a straight shot at the IC
Edited by Turbo This.. on 29th Aug, 2013.
skolawn
Member #: 69
Coventry
Lets apply rocket science for a moment.. the idea is a bit like a rocket taking off getting 30ft of ground flipping and nose diving into the ground....
era mini mark
Member #: 10523
OK, I get the picture. if u don't ask u will never know. I have never heard a stupid question in my life. thxs all.
Nothing to stop you ducting cold air in and hot air out this is how my oil cooler was settup (tucked up under a wing) it worked almost too well i had to tape about 20% of the cooler to keep oil temps up
