Page: |
Home > Show Us Yours! > K'lubman Estate | |||||||
21 Posts Member #: 10566 Member |
22nd Aug, 2013 at 08:53:30am
A little back I bought a clubby estate as it was cheap and always wanted another as my first road going mini was a clubby estate.
22nd Aug, 2013 at 08:53:50am
Roughly chopped ready to unstitch the hundreds of spotwelds.
22nd Aug, 2013 at 09:05:28am
Forgot to mention the engines the 160vvc Kseries, I'm going for a lightweight build taking advantage of lighter engine which is supposed to be about 20kg lighter than the Aseries.
22nd Aug, 2013 at 09:31:11am
1170 Posts Member #: 8636 Post Whore Surrey |
22nd Aug, 2013 at 09:41:03am
Haha
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
2094 Posts Member #: 9894 Post Whore Dorking |
22nd Aug, 2013 at 11:04:55am
brilliant! |
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
22nd Aug, 2013 at 11:28:59am
The front frame looks good. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
22nd Aug, 2013 at 12:00:29pm
You were in minimag/world. Very low engine configureation with a pg1. Good times Drives
22nd Aug, 2013 at 01:40:47pm
Looks worse than it is in the photo, but still fairly low, was my older subframe then aswell. The cars like triggers broom in a way =) 4 diff shells over the project and 3 diff engine but its still the same project. |
520 Posts Member #: 189 Post Whore Norway |
22nd Aug, 2013 at 06:19:03pm
Would this engine also fit a round nose? www.shag.no |
22nd Aug, 2013 at 06:36:16pm
It's going to be a round nose when it's finished, but have kept the clubby parts if I ever want to go back. |
24th Aug, 2013 at 07:11:30pm
28th Sep, 2013 at 08:37:50pm
]Finally got the two halfs of my shell blasted and back in one piece which was a big hurdle I was dreading.
28th Sep, 2013 at 09:18:05pm
good work! |
6729 Posts Member #: 618 Post Whore Glasgow |
29th Sep, 2013 at 07:33:33am
Coming together! |
1 Posts Member #: 10287 Junior Member |
30th Sep, 2013 at 08:56:55am
Can I ask where that rear beam comes from? |
30th Sep, 2013 at 09:34:24am
On 30th Sep, 2013 Lomond26 said:
Can I ask where that rear beam comes from? minitec http://plusmodmini.co.uk/products/other-ki...r-subframe-kit/ |
Page: |
