Page: |
Home > For Sale > Freshly bored 1293 block 11 stud also 1300gt block | |||||||
![]() 279 Posts Member #: 10230 Senior Member |
18th Aug, 2013 at 04:08:43pm
Hi I'm not going to use these anymore so looking at selling them on.
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
18th Aug, 2013 at 04:24:55pm
I'm very interested in the GT block - where are you ? Metric is for people who can't do fractions. |
18th Aug, 2013 at 04:30:32pm
I'm near high Wycombe mate |
18th Aug, 2013 at 04:46:01pm
Heu they both got the correct caps with them? Drives
18th Aug, 2013 at 04:48:28pm
The 1300gt has caps I also have the rods and crank that I might sell if the right offer was there. I have a set of caps off another 1275 that I can give with the 1293 |
18th Aug, 2013 at 04:50:01pm
Caps are matched to the block, you need to have the right ones for the block or you need to do some expensive machining to get it sorted out. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it ![]() |
18th Aug, 2013 at 04:52:53pm
I've just been informed that the caps are specific to an engine so I guess I will have to buy a new centre strap for my other engine. Is this true?? I'm new to the engine side of things |
18th Aug, 2013 at 04:54:22pm
On 18th Aug, 2013 apbellamy said:
Caps are matched to the block, you need to have the right ones for the block or you need to do some expensive machining to get it sorted out. |
18th Aug, 2013 at 04:55:11pm
Just get the centre cap machined on the block you are going to use and leave the matching caps with the block they belong to. On 11th Feb, 2015 robert said:
18th Aug, 2013 at 04:57:20pm
Thanks that's what I will do thanks again for the info. |
18th Aug, 2013 at 04:58:42pm
So has the 1293 got the right caps? I have started posting on Instagram also my name on there is turbomk1golf
18th Aug, 2013 at 05:00:49pm
Yes it will have the caps that go with the block I will just be keeping the strap |
![]() 1170 Posts Member #: 8636 Post Whore Surrey |
18th Aug, 2013 at 05:29:45pm
a new strap is £6
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
18th Aug, 2013 at 05:36:01pm
Ok will leave that as well I'm rubbish at this selling stuff lark |
19th Aug, 2013 at 06:55:31am
PM sent. Metric is for people who can't do fractions. |
Page: |
