Home > Good Garages & Parts Suppliers > Polestar ECUs
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
Great value for money and Neil who owns Polestar is a very helpful chap.
16V project underway
WRLondon
Member #: 8636
Surrey
is it the same polestar that do those fantastic tuned up volvos?
Reading up on RTS Clutches
Turbo Tim
Member #: 177
Woburn Sands
no, he just does the ECUs
He had a turbo mini it was in one of the mags
Turbo Tim
Member #: 177
Woburn Sands
He will do a good price for TM members I'm sure
Is that who's ECU you are using Tim? If so is that with an SC throttle body?
Turbo Tim
Member #: 177
Woburn Sands
yes and yes : )
PEP
Member #: 1145
North Wales
What exactly do you get from them? Just the ECU?? What's needed??
Thought of buying this myself!
Turbo Tim
Member #: 177
Woburn Sands
you have various options, the full kit with loom, trigger wheel and ecu or you can just buy the ecu, he writes the software to suit your car to, if you do fancy buying on tell him your off the forum and know me
http://www.polestarsystems.com
POLESTAR HS Turbo Fuel Injection System £325 surely the cheapest efi ecu around?
Turbo Tim
Member #: 177
Woburn Sands
yes and does the job too
but it can only handle to 22psi of boost?
also who is "licensed/trained" to map it? found it lol
Edited by Paul R on 16th Aug, 2013.
seems great value, and allows you to buy the bits of the kit over time.. I woul dhave given it a go if I hadn't got the SC kit..
