Page: |
Home > Beginners Tech > Breather Issues and Options | |||||||
134 Posts Member #: 9579 Advanced Member Tadley, North Hampshire |
14th Aug, 2013 at 09:29:17pm
So I've gleaned what I can off the forums and think I have a plan, but as usual i need your help. As I'm tuning the mini for track day performance, I'm thinking it might be a plan to put in a proper breather system rather than atmospheric venting. Also, my transfer case breather appears to have developed a bad leak around the gasket since my rebuild, and I'm wondering if this is exacerbated by the straight cut drops I have just put in throwing oil directly at the breather. Either that or perhaps it is blocked? I don't think so though, as there was some oil on the underside of the inter cooler hosing that passes over the breather. Thoughts?
My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970 |
2488 Posts Member #: 1954 Post Whore Luton Bedfordshire |
15th Aug, 2013 at 09:59:43am
If your going to run a catch tank then in my mind you won't need the strainer/filter portion of the standard breather so what you have planned sounds fine. Edited by Mr Joshua on 15th Aug, 2013. Own the day
825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
15th Aug, 2013 at 10:52:33am
This is my setup not a track car so not sure what if anything would need changing, the only thing not on the pic is the timing case breather it is taken to the other end of the rocker cover, just a pipe from top of the timing case. Alan
Main Build
3004 Posts Member #: 2500 Post Whore Buckinghamshire |
15th Aug, 2013 at 03:39:59pm
I suggest that 13mm is the absolute minimum size for breathers, although it is not easy to manage bigger ones for all outlets |
29th Jul, 2015 at 07:52:59pm
Here's a picture of my final implementation. Pretty pleased with it. shortened the standard breather on the flywheel casing to fit under my intercooler (not fitted in this picture)
9502 Posts Member #: 1023 Post Whore Doncaster, South Yorkshire |
29th Jul, 2015 at 08:02:11pm
Holey thread resurrection batman
Yes i moved to the darkside
29th Jul, 2015 at 08:26:58pm
The inside diameter of the Mocal catch tank connectors is the same, so I'm not sure larger hoses would have been hugely beneficial in this particular setup. Not much room to fit a larger breather to the crankcase side either. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970 |
Page: |
