Home > For Sale > Plenum Cut Outs
t@z
Member #: 452
Chester, UK
As some of you maybe aware i got these cut out a while ago, now i've made mine see pic below. But i have now 2 spare cut outs that i no longer need that a would be candidate can use to cut, make into there own thing.
this is mine
plenum by lilpinkiy, on Flickr
These are water jet cut so very accurate and all my holes lined up. As you can see they are flat sided so you can have your plenum either way around also.
The main whole is the exact size of the restrictor ring ID and you can either take and extra 1.5mm out of the hole and fit your own ring from the original plenum or get some ali tube and weld it onto the back in effect making your own ring (make sure the tube ID is the same as the hole if you leave it as). this area you will need to use your own understanding of what you are doing, plently of info on here.
plen_sale by lilpinkiy, on Flickr
I got 3 cut so have 2 spare and it cost me just over £90, so i think a price of £35 posted is fair as i'm not gaining anything from selling them, just want to cover the postage hence the £5.
2 x plenum cut outs £35 posted each
1 x plenum cut outs £35 posted
I also have a gt17 actuator as removed from my GT17 as it's not required by me. £12 posted.
Edited by t@z on 14th Aug, 2013.
www.twitter.com/lilpinkiy
dazibee
Member #: 1356
TRURO, CORNWALL
Are they made from stainless steel. If so I will take one of them please
t@z
Member #: 452
Chester, UK
they are 3mm ali sorry dazibee. forgot to mention
dazibee
Member #: 1356
TRURO, CORNWALL
I'll pass then. I can't weld Ali Cheers
jamestar
Member #: 9159
Devon
I will take one please taz! I've pm'd you!
t@z
Member #: 452
Chester, UK
pm'd mate
benjy_18
Member #: 9378
Chobham
Taz ill take the other!
