Home > Show Us Yours! > Stealthy launch control / omex clubman install how to
WRLondon
Member #: 8636
Surrey
Just installed launch control & revlimiter to the mini but had difficulty finding a place to mount the button
That doesn't look crap (prefer not to see it at all)
Ended up going with;
Box & wiring in the dashboard glove compartment
And launch control button in the gear knob
How to;
Get a cheapish gear knob with chosen logo at the top from moss Europe
With a sharp knife run it around the logo & prise off with a screwdriver
Drill from the bottom to the top to get the hole centred, then procide to go crazy (avoiding the plastic) until the button fits securely inside
Then drill a very small hole in the plastic where it screws on, being careful not to go to near the thread
Feed the wires through the hole and push the button in place
Test to see if the button can still operate and not have much of a gap at the top
With a very small amount of glue or silicone on the top of the button rest the logo on top and allow to dry
I let it dry for about 30mins & to avoid mistakes put a blob of the same glue on a piece of cardboard at the same time to test, do not want it sliding about!
Then screw it on and secure wires with black electrical tape down the shaft to keep the stock look
& cover it with a gaiter like I am :)
Then go out and proceed to launch your car every time you come to a stop like a knob haha
Could use it as a start button too I guess for added security
But good way to spend the Sunday
Wiring diagram is nice and simple
Edited by WRLondon on 4th Aug, 2013.
Reading up on RTS Clutches
vids? *happy*
there a turbo killer so dont get too excited with it lol
good stealth work btw!!
WRLondon
Member #: 8636
Surrey
Thanks
Vid coming soon haha
evolotion
Member #: 83
Glasgow, Scotland
i had mine monted on my gear lever, it was hopeless to time it consistantly when launching was only any use for showing off in carparks. have the switch on an ajustable spring on the clutch pedal and its super consistant and also allows for use when flat shifting :)
Denis O'Brien.
Rammie2000
Member #: 10190
belgium
So just pedal to the metal let it go woootomtom for few seconds pop the clutch and of you are... like rally cars? Nice ,sounds like true fun!
WRLondon
Member #: 8636
Surrey
It's not bad on the gear knob as you really don't have to time it, just let go of the button when you dump the clutch
The spring could work but even more of a PITA to fit
It is pretty easy to do your own launches but difficult to get the pops, bangs and flames lol
It was on a friends fiesta ST and got given it
Useful to avoid over revving
evolotion
Member #: 83
Glasgow, Scotland
mine was on the gear lever origionally, and i beg to differ, found the timing of it compared to the letting up of the clutch had a drastic effect on traction off the line but our engines are very different :) and i have the timing co-ordination of a potato according to my mates when i attempt to play drums. so it doent come naturally lol.
Denis O'Brien.
madonminis
Member #: 9371
East Yorkshire
Awesome stealth job.
oliver122
Member #: 9625
did you ever make any vids of this bud ?
WRLondon
Member #: 8636
Surrey
Late reply but yeah i did Lol
will post them when ive got time :)
Rick.SPI
Member #: 8027
Wanna see tge vids of this, goin to be using the l-c on my dta...
I'd probably use unshrunk heatshrink instead of electrical tape, would look a whole lot neater, and no sticky mess when you remove it. But apart from that, nice work!
TurboMike1992
Member #: 9928
Hartley, Kent
Wr, could you please get back to me about these pistons you wanted to buy off of me.... Thanks.
Low boosting for now.
Chalkie
Member #: 9764
Northamptonshire.
Do you have to hold the button to launch it or dose it kick in and once your going turn off?
