Home > Wanted > wok, for old type clutch
I could do with one of these as a replacement for one I am sending out with a front frame,
hopefully Andy or john will come up trumps so I can allow then to say they know me for one more week,lol
cheers carl
I thought they were all the same
All the same mate, just different arms and plungers, I've interchanged quite a few.
now then gents what would you say if I told you they were not all the same,
even if they have the clutch arm adjuster thread in there I have found what I think is a difference , and its a small counter bore where the release bearing sits into on the inside of the wok,
the difference could just be down to ages but Ideally one with c/b in place, to save me a job,
but lets see what the tarn boys come up with
Will have a look in container at weekend.
Interesting
John, were is the apostrophe between in and container, call your sen yorksha,lol
I have several in the shed. Will drop you one in later in the week. All from 'A' engines rather than A+.
thank you, you can kiss the baby
Saves me a job.
I'm doing nothing of the sort. Pervert.
See no's 3, 4 & 6.
http://www.urbandictionary.com/define.php?...ss%20the%20baby
Yep they are indeed different carl !!
Rick
spaceframemini
Member #: 7472
stockton on tees
I found this out the other week
Andy
Gavin Wakely
Member #: 793
I thought they were all the same for yrs, but over the yrs I've had many differnt wok covers, Metro / Mini / Allegro / Autin 1100 -1300 & I have found some up to 200gsm lighter than others of the same style. Maybe it is down to casting techniques and materials over the yrs.
Any operational differences?
yes *happy*
Never noticed this before
Found 3 woks in the shed. Two with counter bore and one without.
danb41
Member #: 9285
Oxfordshire
Probably being dim, but what affect does this have on clutch operation?
Edited by danb41 on 31st Jul, 2013.
Put a pic up!
They are buried again. It's very obvious if you are looking.
jonny f
Member #: 9894
Dorking
Bringing this up again, anyone know if they have differences in operation or is it ok to interchange?
I'm using one that came out of a preverto and will be using a verto.
Edited by jonny f on 8th May, 2015.
