Page: |
Home > A-Series EFI / Injection > triger wheel for ms3x | |||||||
25th Jul, 2013 at 09:49:56am
id like to have the shop mill my front pulley for the hall sensor is there any specific measurements for depth or size? i be leave it should be a 36:1 wheel just wanted to check if i had them measure the diameter of the pulley and divide that into 72 equal sections 36 high (non milled) and 36 low cut away parts? with the missing tooth in the 90 degrees out spot ? |
971 Posts Member #: 3228 Post Whore North of the Netherlands |
25th Jul, 2013 at 01:56:10pm
I think the best thing to do is get someone to mill 36 slots in your MPi crank pulley.
Dazed and Confused.... |
26th Jul, 2013 at 09:36:39am
i see cheers mate ill ask them about it before they balance the rotating assembly
26th Jul, 2013 at 02:25:02pm
I think I used a 7mm cutter when I did my S pully, On 28th Aug, 2011 Kean said:
27th Jul, 2013 at 10:36:06am
Any pictures of that S pulley?
27th Jul, 2013 at 11:43:13am
theres a couple of the first and second page here...
27th Jul, 2013 at 12:21:29pm
If you are using a Hall switch (rather than the more usual VR sensor) you can, in my experience, get away with a much lower valley depth than a VR would like. You did say hall switch in the first post ???
27th Jul, 2013 at 12:40:44pm
Good info Rod,
27th Jul, 2013 at 02:30:34pm
On 27th Jul, 2013 Joe C said:
theres a couple of the first and second page here... http://www.turbominis.co.uk/forums/index.php?p=vt&tid=119064 Cheers Joe.... made me read the whole thread.... quite a saga.. Interesting indeed Rod, cheers Dazed and Confused.... |
7th Aug, 2013 at 07:40:07am
thats the pulley + balance/dampener ring ill be using
Page: |
