Home > For Sale > Lots of engine parts!
Chris-G
Member #: 10229
Stroud
For sale is a short 1275 turbo engine that i bought of ebay about a year ago. In need of a rebuild but all looks good. Didnt use it as i have since purchased a new engine.
Includes:
Block with pistons, rods, crank, cam & timing gear all still attached.
Head with valves and springs but no rockers.
T3 turbo (some play) on exhaust manifold.
Inlet manifold (from memory i have 2 of these)
Plenum (that someone had bodged a 25mm oulet to) and elbow
Please be aware that all parts will need at least a good clean before use.
I may have some other bits also. Photos available upon request.
Located in Gloucestershire but some parts can be posted.
Im open to sensible offers. Thanks.
This needs a price mate.
Chris-G
Member #: 10229
Stroud
Ok, im not sure what its all worth. I would like to think £300 for the lot?
madonminis
Member #: 9371
East Yorkshire
Dam it. Why want this advertised Wednesday. Grrr
Tremayne
Member #: 10441
Carb included?
WRLondon
Member #: 8636
Surrey
Whats the number stamped on the crank fella?
Reading up on RTS Clutches
Chris-G
Member #: 10229
Stroud
No carb im afraid, as for the number on the crank you ask for, where would i find this?
Its cast into the crank web
WRLondon
Member #: 8636
Surrey
Should be CAM and then some numbers?
Chris-G
Member #: 10229
Stroud
Ok i will take a look. Im not with the engine currently so i will check and post it on here.
Chris-G
Member #: 10229
Stroud
So number on the crank is CAM 658 and then what looks like a 1 or i??
I believe the engine code is 12HC16AA
