Page: |
Home > 998cc > 12G295: Hardened seats important? | |||||||
55 Posts Member #: 909 Advanced Member |
10th Jul, 2013 at 05:25:27pm
I've got a couple of 12G295 heads and am wondering, with a small bore (either 998 or 1098) running 8psi possibly 12ish psi (8:5:1 compression and gt1544 turbo), am I tempting fate by not using hardened valve seats and just running the fresh cut but otherwise stock seats and large collet stock valves (uprated springs and caps, though)?
10th Jul, 2013 at 05:58:25pm
As long as you use some kind of fuel additive then it won't be a problem.
855 Posts Member #: 951 Post Whore Bromsgrove |
10th Jul, 2013 at 06:25:56pm
I've run 5 years/4000 miles turbo but non-hardened seats w/out recession. 'Where does the engine go?' |
9812 Posts Member #: 332 Resident Cylinder Head Modifier Mitsi Evo 7, 911, Cossie. & all the chavs ...... won no problem |
10th Jul, 2013 at 08:10:45pm
addative added steve ?
10th Jul, 2013 at 09:54:20pm
No,Steve,unless you count some rather volatile octane improver! I run big valves and have always been more concerned about head cracking across the valve bridge area than recession.Cutting into that area to fit inserts can only increase the risk of cracking. 'Where does the engine go?' |
10th Jul, 2013 at 10:07:19pm
right
12 Posts Member #: 10441 Member |
10th Jul, 2013 at 10:17:24pm
I had hardened valve seats put in mine when I had it skimmed and new valves put in, but there's a wealth of anecdotal evidence which suggests it's not really worth it. |
7763 Posts Member #: 74 I pick holes in everything.. Chief ancient post excavator |
10th Jul, 2013 at 10:17:49pm
On 10th Jul, 2013 steve1275 said:
No,Steve,unless you count some rather volatile octane improver! I run big valves and have always been more concerned about head cracking across the valve bridge area than recession.Cutting into that area to fit inserts can only increase the risk of cracking. I wholeheartedly disagree!! On 13th Jul, 2012 Ben H said:
10th Jul, 2013 at 11:29:53pm
unleaded inserts are fitted as standard to all my heads, but in your case steve, theres not enough meat,
Edited by BENROSS on 10th Jul, 2013.
11th Jul, 2013 at 04:32:28am
Once again, I appreciate the varied and first-hand experience responses. I've run heads without seats and without additive for quite a long time. My largest concern was regarding the specifics of the turbo application. My perhaps irrational thinking was that since the exhaust valves can or perhaps do get hotter then the "blowtorch" effect could apply more quickly and burn through an exhaust seat in short order.
11th Jul, 2013 at 06:54:14am
Sorted!
Page: |
