Page: |
Home > Help Needed / General Tech Chat > cam timing without taking head off... | |||||||
8 Posts Member #: 9032 Junior Member |
30th Jun, 2013 at 10:41:04am
right, I'm about to fit new duplex timing gears to my engine, to replace the belt drive kit which seems to never stop leaking (yes tried all the usual tricks).
361 Posts Member #: 114 Senior Member Porto/Portugal |
30th Jun, 2013 at 10:49:27am
Pedro Silva
30th Jun, 2013 at 10:53:33am
using the DTI in the spark plug port isnt very accurate unless the DTI screws into the plug hole - which mine doesnt... |
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
30th Jun, 2013 at 11:04:45am
Is there timing marks on the flywheel you can use for tdc? On 26th Jan, 2012 Tom Fenton said:
30th Jun, 2013 at 11:13:37am
None on the flywheel as its an ultralight... |
1170 Posts Member #: 8636 Post Whore Surrey |
30th Jun, 2013 at 11:51:42am
Headgasket isn't very expensive and timing is pretty important
Edited by WRLondon on 30th Jun, 2013. Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
8297 Posts Member #: 408 Turbo Love Palace Fool Aylesbury |
30th Jun, 2013 at 03:09:44pm
Just use a finger type Dti In the plug hole, it should reach fine. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
3587 Posts Member #: 655 Post Whore Northern Ireland |
30th Jun, 2013 at 06:19:19pm
OR adapt with a bit of welding rod, coat hanger etc etc.
2488 Posts Member #: 1954 Post Whore Luton Bedfordshire |
1st Jul, 2013 at 08:17:11am
Pull the head of Own the day
12 Posts Member #: 10502 Member |
1st Jul, 2013 at 07:46:46pm
One of the ways it can be done on indirect diesels (pre chamber in the way of the injector holes) is to pull off a valve spring and rest the valve on top of the piston, then put the DTI on the valve. For me this would be a last resort, but if you do make sure you don't turn the crank very far, and make sure those collets go back properly.
1st Jul, 2013 at 07:53:06pm
use the dead stop method to find true tdc and mount the protractor in the right place. On 28th Aug, 2011 Kean said:
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
1st Jul, 2013 at 08:05:47pm
you do need a very sturdy dead stop ( (if the plug is angled) that reaches deep enough to touch somewhere near the centre of the piston otherwise the rock of the piston gives grief.
Edited by Sir Yun on 1st Jul, 2013. That sir, is not rust, it is the progressive mass reduction system
Page: |
