Page: |
Home > Show Us Yours! > robs leyland mini S | |||||||
54 Posts Member #: 2819 Advanced Member south east, Melbourne, Victoria, Australia |
30th Jun, 2013 at 08:37:11am
Hello all, my name is rob, I live in Melbourne Australia. I’ve been on turbominis for a while now and I thought I better get my arse into gear and start to turbo my car. I’m doing this on a budget because I’m a tight arse. So I will be begging, borrowing and using friend’s machine shop as much as I can and most of this stuff I have sourced from wreckers yards, off friends and good old dodgy eBay,
everybody likes free stuff |
1043 Posts Member #: 10424 Post Whore Swansea boyo! |
30th Jun, 2013 at 08:43:13am
Lovely colour, good luck! They don't die, they just get faster! |
538 Posts Member #: 9393 Use the search function before buying stuff from me... stoke on trent |
30th Jun, 2013 at 04:47:09pm
Throttle valves interesting! |
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
30th Jun, 2013 at 05:02:42pm
Your exhaust manifold might blow slightly. On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
16th Nov, 2013 at 09:15:01pm
a bit of an update doesnt look ive done much but had a heap of other things on
10th Dec, 2013 at 09:17:04am
started to make the fuel rail up, started to weld the injector bosses in last night, the two green injectors are bosch 440cc ones,
3673 Posts Member #: 9300 Post Whore Quarry Bonk |
10th Dec, 2013 at 09:24:04am
Nice looking car, some good progress going on! On 26th Jan, 2012 Tom Fenton said:
10th Dec, 2013 at 09:26:51am
thanks its slowly getting there, just trying to fit everything in and mocking up parts beofore i respary so i dont have to cut everything i just painted everybody likes free stuff |
10th Dec, 2013 at 08:08:53pm
How does the heater take off being attached to the rocker cover work? |
11th Dec, 2013 at 05:57:51am
its just sitting there at the moment, i have a water heated manifold but i couldnt be bothered taking the hose off all the way, im not leaving it like that, im not that dumb everybody likes free stuff |
11th Dec, 2013 at 07:15:02am
Wasn't trying to imply you were dumb!
12th Dec, 2013 at 05:31:16am
its factory breather the pipe goes back into the round air filter on std cars,
12th Dec, 2013 at 06:54:55am
On 12th Dec, 2013 norm74 said:
sorry i didnt know that you guys didnt have them over there. Some people add one in that location but UK spec for breather location is tappet chest cover on small bores and flywheel housing plus timing chain cover for large bore. Also, unless it's just a trick of the photography, it looks like your head is held on with bolts.... Unless someone tells me otherwise, I've only ever seen studs and nuts used over here. Schrödinger's cat - so which one am I ??? |
12th Dec, 2013 at 07:24:30pm
I thought cooper s were bolts
12th Dec, 2013 at 08:58:11pm
As Rod says, in the UK many people add a cover breather and indeed some early Minis had one as standard but it was a simple pipe take off, not the block you have on top of the cover. Is there a flame arrestor gauze in that bit?
118 Posts Member #: 9965 Advanced Member Sydney, Australia! |
16th Dec, 2013 at 12:07:49am
most aussie 998 and 1098's came out with Bolts as opposed to studs, was cheaper, compression wasnt too ridiculous to warrant the need of the fancy studs etc.
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson |
16th Dec, 2013 at 07:22:06am
yeah matts right, my 1098cc came factory with bolts, like he said there cheap. i didnt know that all the uk engines just had studs, and different breathers, mine will just vent downwards, thats what most people seem to do over here
Page: |
