Home > Wanted > Two bolt front subframe
Bit cheeky but has anyone got a cheap good early front subframe?
Scudy23
Member #: 10087
Very wet south wales
I got a front subframe but its off a J plate if thats early enough.
jonny
Member #: 2322
rednal birmingham
ive got one, just took it off, it will need shotblasting, its very rusty but no holes, if you want it you can have it, as ive got a brand new one
YOU CANT POLISH A TURD, BUT, YOU CAN ROLL IT IN GLITTER!!!!
Make one neil *smiley* tubular front, rear and middle like mikerace's one still uses the towers so you can retain your cones.
hi jonny where is rednal?
what year is it off
jonny
Member #: 2322
rednal birmingham
its off a J reg, 1971, just had a good look at it, and the metal is starting to flake and separate on the offside tower, so its worse than i thought, if you still want it, its yours for free, still has the front drums and and suspension on it too, rednal is south birmingham near bromsgrove*smiley*
Edited by jonny on 24th Jun, 2013.
Thanks Jonny, i think i will give it a miss
So still looking for a pre 76 front subby
jonny
Member #: 2322
rednal birmingham
No worries mate, I just put it out for the scrapman, and went back to my garage (10 meters away)to put the stuffed rear subframe out too, and there he was, how quick was that!!!
