Home > Wanted > Front panel 76 > and a pair of wings
MarkGTT
Member #: 1194
Shropshire.
Hi, I'm after a few panels - Front panel 76 > and a pair of wings
Cheers Mark
Drivers wing:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=523533
Should be able to get it to you via TM Courier.
MarkGTT
Member #: 1194
Shropshire.
Cheers Andy, Shame it has a repeater hole tho.. Will let you know if the one I'm after doesn't turn up.
Minispares magnum front panels are an amazing fit, I'd recommend you get one of those!
MarkGTT
Member #: 1194
Shropshire.
Cheers Carl, I've just fitted a heritage item and to be fair it took a bit if work so it's worth a punt.
welshdan
Member #: 1111
s wales
Though magnum wings are miles out...
Had two fitted to two separate cars, I witnessed the first and the second has been fitted to Shauna's mini, it was like they grew there in both instances
