Home > FAQ / Knowledge > Max Boost on std Engine
enne
Member #: 9827
Germany
searched about this and just found 10psi when fuelling and ignition is suited.
Is this right?
Thanks
Adding an intercooler may help you raise the boost slightly.
enne
Member #: 9827
Germany
I know. Donīt want to do this, as i have an ERA. Want to keep stock-look.
But thanks.
Edited by enne on 5th Jun, 2013.
jamiestevenbell
Member #: 9941
Derby
I think you may be brave at 10psi on a completely standard engine with no intercooler
redrat
Member #: 9107
Devon
If its an era and in stock form I would not run more that 7 to 8 max . Would be a real shame to bugger it for the sake of 10 or so bhp .
alaskanow0
Member #: 8466
Mansfield
Why not have the chambers open to 23cc to be safe. You can keep the standard shape chamber at that.
Edited by alaskanow0 on 5th Jun, 2013.
enne
Member #: 9827
Germany
HI,
I donīt want the ponnies, more the torque. Have started to make a head, but donīt have the time at the moment to finish it.
Sure, I donīt want to roast my engine. Thats why Iīm here!
Thanks
Block off the ecu bleed valve jobbie and adjust/replace your actuator to give about 9-10psi. Setup will have to be bang on though. Should make 100ponies and torques and feel a damn site quicker than standard due to not having the boost modulation thingy that keeps the boost down till high revs.
Change the cam, head work and exhaust manifold/elbo ported
8 psi and thats it on that compression and no intercooler, if you frig the ecu you will trash the standard helical gearset. it will all end it tears
enne
Member #: 9827
Germany
... Should have gone to straight cut gears three jears ago, when i got a new gearbox....
Have straight transfer gears already.
Will set to 8psi and try not to go mad..
Thanks to all!
Edited by enne on 6th Jun, 2013.
welshdan
Member #: 1111
s wales
I have a stock looking intercooler in the for sale section.
jamiestevenbell
Member #: 9941
Derby
I have just fitted a bini diesel intercooler in my mini behind the grill and its perfect size wise for a round nose mini without butchering it!
