Home > Wanted > Plastic inner headlamp bowl and spring adjuster
jarmour116
Member #: 10044
Ballymoney, NI
Hi, im after one of the inside plastic bowls fitted to the back of the headlamp on a 95 cooper. it looks like the one in this listing http://www.ebay.co.uk/itm/Classic-Mini-Hea...=item2c6e39b279
also looking for the adjuster spring which sits in the back bigger bowl.
Thanks
if you come up with no joy from our good members, try minispares
jarmour116
Member #: 10044
Ballymoney, NI
thanks. does anyone know if this inner bowl is needed to fit wipac headlamps? i read elsewhere that its not.
