Page: |
Home > 998cc > Carb jet? | |||||||
84 Posts Member #: 10419 Advanced Member |
8th May, 2013 at 10:35:16pm
I Recently got my hands on a HIF44 That im going to be converting to handle a blow though but I was wondering what jet i should use. It is running on a 998 that was bored .60 would the standard jet from a 1275 be good or would if be worth while changing it up slightly. |
4625 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
8th May, 2013 at 10:39:18pm
The jet is standard, you change the needle profile to alter fuelling. You'll ideally need a session on the rollers to get the fuelling set up correctly. |
3329 Posts Member #: 184 Senior Member Melton Mowbray, Pie Country |
9th May, 2013 at 08:38:36am
As Phil says the needle you choose will only be the starting point and the jet is fixed.
http://www.twin-turbo.co.uk
9th May, 2013 at 02:39:19pm
Thanks gents, I cant wait to get this project started! |
Page: |
