Page: |
Home > A-Series EFI / Injection > Injector position? Before or after S/C? | |||||||
73 Posts Member #: 10315 Advanced Member |
3rd May, 2013 at 11:37:49pm
I am about to start making my manifold for my supercharger and wanted some opinions on where to locate the injectors. I am planning on running two injectors either at the top of the S/C where the inlet pipe connects or into the back of the inlet manifold like a direct injection set up.
6th May, 2013 at 11:31:51am
Anyone????
6th May, 2013 at 11:39:26am
after the SC, the Eatons dont like fuel going through them it kills the teflon coating. On 28th Aug, 2011 Kean said:
6th May, 2013 at 12:38:19pm
Thanks Joe. Good point. |
7 Posts Member #: 10411 Junior Member |
22nd May, 2013 at 11:52:56am
I'm really interested in this, has anyone ever put the injectors after the sc? Surly it will cool the charge air temperatures?? Currently build my manifolds or my mpi |
22nd May, 2013 at 11:54:25am
22nd May, 2013 at 12:31:18pm
Yes is the answer. If you are building it as such you are really building a blow through system.
Page: |
